Infinite chain of alternating charges (+/-)
In summary, a crystal is a periodic lattice of positively and negatively charged ions. When considering an infinite one-dimensional crystal of alternating charges +q and -q separated by distance d, the potential energy per ion can be calculated by taking the sum of the potential between one +q and -q set and dividing it by the number of ions. However, there is potential between multiple charges, so it is necessary to be careful not to over-count. Another approach is to take one charge out of the chain and consider the work done in adding it back in, which would involve considering the potential at all other points in the chain.
starstruck_
185
A crystal is a periodic lattice of positively and negatively charged ions.
(a) Consider an infinite one-dimensional crystal of alternating charges +q and −q, separated by distance d:
(+q)--d--(-q)--d--(+q)--d--(-q)---d--(+q)--d--(-q)--d--(+q)--d--(-q)--d--(+q)--d--(-q)--d--(+q)--d--(-q)--d-- [...]
What is the potential energy per ion?
This is a second year electricity and magnetism problem set that I'm attempting ( found my professor's previous problem sets online, I haven't started the actual course - it starts in the Fall)
From first year, I know that the potential energy between two charges is V= kq1q2/r
I know I definitely don't have the answer (might need someone to "talk" me through it ) but this is what I was thinking.
If there is an infinite number of (+q) and (-q) sets , I could take an infinite sum of the potential of one set (so between one +q and -q )and then divide out by the number of ions. If n is the number of (+q) and (-q) sets then the number of ions would be 2n?This seems wrong though, because there is potential between q1 and q2 and then q1 and q3 and q3 and q2, so on and so forth.
What if you imagine assembling this crystal one charge at a time? How much work is done adding a charge to the chain?
Not sure that helps. Seems more straightforward just to pick one charge and add up all the potentials at that point from all the others.
One ambiguity though: it says "infinite" but the diagram shows semi-infinite.
I'm almost certain we need to work with it being infinite, that's just how the diagram was drawn on the paper- a few ions and then a [...].
If we take one charge and then add up the potentials from that charge to the others, would it be something like
∑ (-1)^(n+1) kq1(qn+1)/(d(n-1))
and then divide that by the number of ions (n) ?
Not quite. What is the lower bound on n in your sum? What is the least distance?
All the charges are equal.
Why?
Why?
The lower bound on n in my sum is 1
I was using n to represent the number of ions from 1 to infinity.
It asked for the potential for each ion so I assumed I could divide out the total potential by the total number of ions.
What does the n=1 term look like in your sum?
But your sum is not the total PE of the chain. It is only that of one ion.
Ahh because i’ve written my sum relative to ONE ion?
The n=1 term is undefined
Yes.
I don't understand why you have d(n-1). The closest any two can be is d.
Can you perform the sum?
haruspex said:
Yes.
The distance of any charge from the first one would be d(n-1)
If n=1 is the first charge, the potential is undefined since d(1-1) = 0
when we add another charge, so n= 2, we know that the distance between them is d, d(n-1) = d(2-1) = d
When we add a third charge, so n= 3, we know that the distance between the 1st and 3rd charge should be 2d.
d(n-1)= d(3-1) = 2d
And so on.
If I preform the sum I’ve written
When n= 1, the sum = undefined
When n= 2, the sum = (-1)^3 (e)(e) /d
= -e^2/d
When n= 3, the sum = (-1)^4 (e)(e)/2d
= e^2/2d
The signs keep changing as the charges are alternating between +/-
When n=4, the sum = -e^2/3d
When n= 5, the sum = e^2/4d
... then the sum should start at n=2. No work is done positioning a charge at itself.
Right, but can you perform the sum? It is one you should recognise.
If not, try using generating functions. Multiply the nth term by sn and see whether integrating or differentiating wrt s simplifies matters.
It is the same result as long as you do not over-count. The hazard is that by adding up the potentials at that point from all the others you have potentially double-counted. You have to remember to divide by two because you've already implicitly counted the potential at all the other points from the one.
Likes haruspex
What if you take one charge out of the infinite chain and then consider the work done
in adding the charge back into the chain?
For the first two adjacent charges : W1 = -2kq / d
and then for the next 2 charges W2 = 2 k q / (2 d)
then you get an infinite series of terms like (2 k q / d) * (-1)^n / n
Then the problem would be to find the sum of that series.
That is where starstruck_ got to in post #10; except that, correctly, the sum there only counts the charges to one side of the given charge. If you count both sides you are effectively double counting, as warned against in post #12.
But it seems if you place one end of the chain at the origin then you have to divide by n (infinity) to
get the potential energy per ion. But if you place the middle of the chain at the origin then you have the
difference of two infinite series that proceed as:
1/2 + 1/4 + 1/6 ... 1/2n and 1 + 1/3 + 1/5 ... 1/ (2n -1)
As you know, subtracting one infinity from another or dividing one infinite quantity by another is a mathematically undefined operation. Such things are to be avoided.
Interleaving the two series termwise as gives you a convergent series. It can be googled.
Edit: removed some of the more explicit hints.
Interleaving the two series termwise as 1/2 - 1/3 + 1/4 - 1/5... gives you a convergent series. It can be googled "alternating harmonic series".
Thanks!
Coming from a mathematical background, I find concepts like "potential energy per charge" in an infinite array to be poorly defined. One would like to have a more formal definition to use. Something along the lines of:
"Suppose that we have finite array of n alternating unit charges with unit separation in one dimension. This finite array has some total potential energy P(n). It has potential energy per charge given by P(n)/n. Evaluate the limit (if it exists) of P(n)/n as n increases without bound."
This probably does not help much with physical intuition. Or even with calculation. But it gives the mathematical approach a well defined starting point that avoids infinities.
right so my sum would just be
Σ(-1)^(n+1)(e)^n/(d(n-1)) from n=2 to infinity
as for recognizing the sum, I'm don't believe this was covered in my calculus 2 course ( a lot of the math is covered by our physics professors instead)
would I just be required to find the limit of the sum?
What is that ##e^n## term supposed to represent? I think that you should have written it as ##q^2##.
You can factor d out of the sum, simplifying it that way.
You dropped the q's out of the sum. That's somewhat OK since those could have been factored out.
Having factored the constants out of the sum, what is left? Can you write down the first four or five terms?
ohhhh, I think I see where to go with this. Right, factoring out the constants from the sum, you would factor out that (-1) ^(n-1),k (forgot to put that into my sum,oops), q^2 and d. You would be left with 1/n-1. This looks like " a/(r-1) "
In post #10 @starstruck_ wrote e2, so I think the en is just a typo.
@starstruck_, did you try the trick I described in post #11?
What do you get if you differentiate ##G(s)=\Sigma_1\frac{(-s)^n}n##?
Likes jbriggs444
You cannot factor out (-1)n since it contains an n.
And yes! Sorry I meant e^2, getting confused with Ns everywhere.
Oh right the n term, I can still factor out (-1) ^ 1, right? So that’ll leave me with (-1)^n/ (n-1)
Yes.
haruspex said:
Yes.
Just got back to this again!
Okay so (-1)^n/(n-1)
I searched up alternating harmonic series as someone mentioned before ( haven't been taught them yet) but looking at what I've read, the limit of this series should be ln(2) ?
You should be able to rewrite that summing from 1 to infinity, making it even prettier.
I believe that @haruspex was attempting to get you to derive this result for yourself.
If you multiply each term by ##s^n## and differentiate with respect to s, you get a result that can be further manipulated. Try it and see.
jbriggs444 said:
You should be able to rewrite that summing from 1 to infinity, making it even prettier.I believe that @haruspex was attempting to get you to derive this result for yourself.
Sorry, why do we multiply by s^n?
Because of the nifty way things cancel when you differentiate.
[It is not obvious until you actually perform the manipulation what magic can then be invoked to provide the result you seek. @haruspex probably knows it inside and out. Me, you have to beat over the head with it]
I was trying to get you to work with the form ##-\Sigma_1\frac{(-1)^n}{n}##, in which you would multiply by sn. But if you are using the form ##\Sigma_2\frac{(-1)^n}{n-1}## then it will be sn-1. You'll see why.
It's a technique worth acquiring.
FAQ: Infinite chain of alternating charges (+/-)
What is an infinite chain of alternating charges (+/-)?
An infinite chain of alternating charges (+/-) is a theoretical model in which an infinite number of positively and negatively charged particles are arranged in a linear chain, with the charges alternating between positive and negative.
What is the purpose of studying an infinite chain of alternating charges (+/-)?
The purpose of studying an infinite chain of alternating charges (+/-) is to better understand the behavior of charged particles in a linear arrangement and how this can affect the overall properties of the system.
How does an infinite chain of alternating charges (+/-) behave?
An infinite chain of alternating charges (+/-) exhibits a unique behavior known as charge ordering, in which the particles align themselves in a specific pattern due to the attraction and repulsion between the charges.
What are the applications of an infinite chain of alternating charges (+/-)?
Some potential applications of an infinite chain of alternating charges (+/-) include the development of new materials with unique electrical and magnetic properties, as well as the advancement of technologies such as batteries and solar cells.
Are there any real-world examples of an infinite chain of alternating charges (+/-)?
While there are no known examples of an infinite chain of alternating charges (+/-) in nature, similar structures can be found in certain crystals and polymers, which exhibit charge ordering due to the arrangement of charged particles within their structures.
