MHB Infinite Geometric Series and Convergence
The discussion focuses on finding the common ratio for an infinite geometric series. For a series with an initial term of 4 that converges to a sum of 16/3, the common ratio is calculated as r = 1/4. Another series is analyzed, leading to a common ratio of r = √5/2, which is greater than 1. Since this ratio exceeds 1, the series diverges. The key takeaway is that a common ratio greater than or equal to 1 indicates divergence in infinite geometric series.
karush
MHB
a. Find the common ration $r$, for an infinite series
with an initial term $4$ that converges to a sum of $\displaystyle\frac{16}{3}$
$$\displaystyle S=\frac{a}{1-r} $$ so $\displaystyle\frac{16}{3}=\frac{4}{1-r}$ then $\displaystyle r=\frac{1}{4}$
b. Consider the infinite geometric series
$\displaystyle
\frac{8}{25} + \frac{4\sqrt{5}}{25}+\frac{2}{5}+\frac{\sqrt{5}}{5}+\cdot\cdot\cdot$
c. What is the exact value of the common ratio of the series
$\frac{8}{25}\cdot r = \frac{4\sqrt{5}}{25}$ so $r=\frac{\sqrt{5}}{2}$d. Does the series converge?
not sure how to do this?
Mathematics news on Phys.org
Hi karush,
Your final answer for part a is correct.
To find the common ratio, $r$, solve $\dfrac{16}{3}=\dfrac{4}{1-r}$ for $r$.
Please show your work.
Part d:
Is $\dfrac{\sqrt5}{2}$ greater than, less than or equal to $1$? What does your answer to this question imply?
$$\displaystyle S=\frac{a}{1-r} =$$
so $\displaystyle\frac{16}{3}=\frac{4}{1-r} \\
3\cdot4 = 16\left(1-r\right)\implies12=16-16r\implies4=16r\implies r=\frac{4}{16}=\frac{1}{4}$b. Consider the infinite geometric series
$\displaystyle
$\frac{\sqrt{5}}{2}=1.11$ $r\ge1$ no it divergess
$r>1$
Correct. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
