Infinite geometric series application (long)
In summary, a patient with chronic pain is prescribed a 240 mg pain-reducing drug to be taken every 4 hours. After 4 hours, 60% of the original dose leaves the body, resulting in a geometric series of the remaining drug in the body. The equation for the amount of drug in the bloodstream is Qe^-(ct), with an initial value of 240 mg and a decay constant of c. After solving for c, the equation becomes y=y0(2/5)^(t/4), with a value of 336 mg after 4 hours. The amount of drug in the patient's bloodstream after the nth dose can be expressed as a geometric series using sigma notation.
sjnt
Assume that the drug administered intravenously so the concentration of drug in the bloodstream jumps almost immediately to its highest level. The concentration of the drug decays exponentially.
A doctor prescribes a 240 milligram (mg), pain-reducing drug to a patient who has chronic pain. The medical instructions read that this drug should be taken every 4 hours. After 4 hours, 60% of the original dose leaves the body. Under these conditions, the amount of drug remaining in the body, at 4-hour intervals, forms a geometric series.
1. Supposing that the patient takes just one dose of the medicine write an equation for the amount of the drug in the patient's blood stream t hours after taking the medicine2. How many mgs of the drug are present in the body after 4 hours? (just after second dose?)3. Graph the amount of medicine in the blood stream for the first 24 hour period.4. Show that the amount of medicine in the patient's bloodstream after the Nth dose can be expressed by a geometric series. Use sigma notation to express the series.
1. Qe^-(ct) where c is a positive constant?
Try writing out the amount of the drug in the body at each time. At time t0, there will be 240 mg. At t=4 there will be 240 mg (next dose) + .4*240 mg (last dose). At t=8, 240 mg (next dose) + .4*240 mg (previous dose) + .4*.4*240 mg (first dose). What does the pattern look like? Can you write an equation for that?
i modified the problem statement a bit.
I had that equation before but it has to be exponential and it has to be decaying. any thoughts?
I see, you are talking about part 1. Well then, use your initial values. You know that the form will be y = y0 e-ct. You know that y0 = 240. Next, y4 = .4*240 = 96. That can solve for c.
1. y=y0e^(-ct)
2. after solving for c, y=y0(2/5)^(t/4)
y(t)=240(2/5)^(4/4)+240mg=336, correct?
4. n-1
240(sigma)(2/5)^c
c=0
Related to Infinite geometric series application (long)
1. What is an infinite geometric series?
An infinite geometric series is a sequence of numbers where each term is found by multiplying the previous term by a fixed number, called the common ratio. The series continues indefinitely, with each term becoming progressively smaller.
2. How is an infinite geometric series used in real life?
Infinite geometric series have many practical applications in fields such as finance, physics, and biology. For example, they can be used to calculate compound interest, model the decay of radioactive materials, and predict population growth.
3. What is the formula for finding the sum of an infinite geometric series?
The formula for finding the sum of an infinite geometric series is S = a / (1 - r), where S is the sum, a is the first term, and r is the common ratio. This formula only works when the absolute value of r is less than 1.
4. How do you determine if an infinite geometric series converges or diverges?
An infinite geometric series converges if the absolute value of the common ratio (r) is less than 1. If the absolute value of r is greater than or equal to 1, the series will diverge.
5. What is the relationship between the common ratio and the convergence/divergence of an infinite geometric series?
The common ratio plays a crucial role in determining whether an infinite geometric series converges or diverges. If the absolute value of the common ratio is less than 1, the series will converge. If the absolute value of the common ratio is greater than or equal to 1, the series will diverge.
9K
  • Calculus
