Infinite number of turns in finite time
In summary, a car moving at a constant speed of 40 km/h along a straight road makes a sharp 90° turn by the side of a wall. At the same time, a fly flying at a constant speed of 100 km/h starts at the wall and flies towards the car, hitting the glass pane and returning to the wall. The fly continues this pattern until the car makes the turn. The number of trips the fly makes between the car and the wall is infinite in a theoretical sense, but in reality, it stops after 30 minutes or 31st minute.
paras02
31
A car is moving with a constant speed of 40 km/h along a straight road which heads towards a large vertical wall and makes a sharp 90° turn by side of the wall . A fly flying at a constant speed of 100 km/h , start from the wall towards the car at an instant when the car is 20km away, flies until it reaches the glass pane of the car and return to the wall at same speed. It continues until the car makes the 90° turn. how many trips has it made between the car and the wall ?
distance = speed * time
Suppose the car is at a distance 'x' away(at A) when the fly is at the wall(at O ) . The fly hit the glass pane at B, taking a time 't'. Then
AB = (40km/h)t ,
OB = (100km/h)t
Thus x = AB + OB
= (140km/h)t
t =x / 140 km/h
OB = 5x / 7
The fly returns to the wall and during this time period car moves BC. The time taken by the fly in this return path is
5x /7 / 100 or x / 140
BC = 40x /140 or 2x / 7
OC = OB - OC
= 3x / 7
Distance of the car at beginning of 2nd trip
= 3*20 / 7
Distance of the car at beginning of 3rd trip
= 32*20 / 72
Distance of the car at beginning of nth trip
= 3n-1*20 / 7n-1
trips will go on till the distance is reduced to zero . this will be the case when n approaches to infinity .hence the fly make infinite number of turns.
But in my view it is not possible as car will take only 30 minutes to reach the wall. Thus fly can't make infinite number of turns.
Well, it depends on what assumption you make. If you assume the fly is pointlike, and the glass can go arbitrarily close to the wall, then the fly certainly can make an infinite number of turns.
In normal cars though, the glass really cannot touch the wall. Perhaps you can use that as a cutoff in your sum.
1/2 + 1/4 + 1/8 + 1/16 + … = 1
similarly, ∑ (1/7)n = 1/6 :smile:
And in that observation you came very close to finding the easiest way to solve the problem.
The period under consideration is 30 minutes, and the fly flies constantly at 100kph, so how far does it fly?
No, but allow that it can make some huge number of turns, N (it's a theoretical fly). That produces an answer which depends on N. As you allow N to increase, the answer gets closer and closer to the value, X say, that you get by allowing N to be infinite. So while you can argue that N is never infinite, the answer can be made arbitrarily close to X, so to all intents and purposes the answer is X.
Suppose a man standing near by observes all this incident. He will notice that at the end of 30th minute or in 31st minute the motion of the fly has stopped. Thus he can count the exact number of trips provided that the man has this ability, but theoretical it is not possible as the distance between fly and car will never reduce to zero. Will you explain this paradox.
If we are dealing with a theoretical model rather than the real world, it will be an infinity of trips.
You have to be careful with what you mean by 'never'. With the usual meaning, that the event will not occur in a finite time, your statement is wrong: the distance will reduce to zero. The Achilles + Tortoise paradox arises because 'never' is taken to mean not within the scope of a given iterative analysis (which is structured so as not to be able to reach the moment in time when A catches T).
ok! thankyou guys
Related to Infinite number of turns in finite time
1. What is an "infinite number of turns in finite time"?
An "infinite number of turns in finite time" refers to a hypothetical scenario in which a rotating object completes an infinite number of rotations within a finite amount of time. This concept is often used in thought experiments and theoretical physics.
2. Is it possible for an object to complete an infinite number of turns in finite time?
No, according to our current understanding of physics, it is not possible for an object to complete an infinite number of turns in finite time. This concept violates the laws of thermodynamics and the principles of relativity.
3. How does this concept relate to Zeno's paradox?
This concept is similar to Zeno's paradox, which states that it is impossible for an object to reach a destination because it must first complete an infinite number of smaller distances. In the case of an "infinite number of turns in finite time", the object must complete an infinite number of rotations before reaching a final position.
4. Can this concept be observed in the real world?
No, this concept is purely hypothetical and cannot be observed in the real world. It is often used as a thought experiment to explore the limits of our understanding of time and space.
5. What are the implications of an "infinite number of turns in finite time" for our understanding of the universe?
This concept challenges our current understanding of time and space and raises questions about the nature of infinity. It also highlights the limitations of our current scientific theories and suggests that there may be phenomena that exist beyond our current understanding.
