Undergrad Infinite Series of Infinite Series
  • Thread starter Thread starter Drakkith
    Series convergence
The discussion revolves around the concept of infinite series where each term is another infinite series, specifically examining the convergence and summation of such series. A key example presented involves the series defined as a sum of terms that are powers of fractions, which converges due to the rapid decay of the terms. The conversation highlights the use of Mathematica to compute the sum, leading to the discovery of the Erdős–Borwein constant, approximately 1.6, which intriguingly relates to the number of divisors of integers. Participants note the importance of careful manipulation of sums to avoid issues like "mass vanishing at infinity." The Erdős–Borwein constant also appears in the analysis of the heapsort algorithm, showcasing its practical relevance.
Drakkith
Mentor
TL;DR
How to solve an infinite series where each term is itself an infinite series?
I had a random thought about infinite series the other day while watching a math video. Let's say we have an infinite series where each term in the series is itself another infinite series. How would one go about finding the sum?
For example, let's say we have the series ##a_1+a_2+a_3...## where ##a_n = (\frac{1}{2})^n+(\frac{1}{4})^n+(\frac{1}{8})^n...##
I assume the series converges since each term is the reciprocal powers of two series raised to a power (without the leading 1/1 term, which would make it diverge), which should fall off quite quickly. However it's been a while since I did any math work involving series so I'm a bit unsure. Thoughts? Is solving something like this fundamentally any different from solving a 'plain' series?
Mathematics news on Phys.org
Sometimes one can reorganize the series by grabbing the first term of each sub series and group them as the first term of a new series.
This is a double sum (akin to a double integral) that we may call ##S##. The inner sum is trivial and Mathematica can compute the remaining sum:$$S\equiv\sum_{m=1}^{\infty}\sum_{n=1}^{\infty}2^{-mn}=\sum_{m=1}^{\infty}\left(\frac{1}{2^{m}-1}\right)=1-\frac{\psi_{1/2}^{0}\left(1\right)}{\ln2}$$where ##\psi_{q}^{n}\left(z\right)## is the q-Polygamma Function.
Likes pbuk, jedishrfu and Drakkith
Excellent! I would have never thought about the series being like a double integral! Thanks so much!
Likes hutchphd and jedishrfu
renormalize said:
Mathematica can compute the remaining sum...
But don't leave us in suspense: the result is the Erdős–Borwein constant (approximately 1.6) and, remarkably, is also equal to $$ \sum_{n=1}^{\infty} \frac{\sigma_0(n)}{2^n} $$ where ## \sigma_0(n) ## is the number of divisors of ## n ##.
Likes Drakkith, renormalize, fresh_42 and 1 other person
Drakkith said:
TL;DR Summary: How to solve an infinite series where each term is itself an infinite series?
You only have to be careful in case you re-order the summations, e.g. swapping the sums or replacing one sum with an integral and swapping sum and integration. In such cases, a phenomenon called "mass vanishing at infinity" can occur. For example, consider the telescope sum
\sum_{k=0}^n\underbrace{
\left(\chi_{[k,k+1]}-\chi_{[k+1,k+2]}\right)
}_{=f_k}=\sum_{k=0}^n \left(\chi_{[0,1]}-\chi_{[n+1,n+2]}\right)\stackrel{n\to \infty }{\longrightarrow }\chi_{[0,1]}
then we have
0=\sum_{k=0}^\infty \left(\int_\mathbb{R}f_k(x)\,dx\right)\neq \int_\mathbb{R} \left(\sum_{k=0}^\infty f_k(x)\right)\,dx=1
This isn't a problem in your example. I just wanted to mention that it can be tricky if two infinite sums are involved.
Likes Drakkith and jedishrfu
And here is the link to the Wikipedia article:
https://en.wikipedia.org/wiki/Erdős–Borwein_constant
I found it interesting that it actually occurs somewhere:
The Erdős–Borwein constant comes up in the average case analysis of the heapsort algorithm, where it controls the constant factor in the running time for converting an unsorted array of items into a heap.
Likes Drakkith, renormalize and jedishrfu
Well, I'm glad I picked an interesting example!
  • Haha
Likes pbuk and fresh_42
  • · Replies 20 ·
  • · Replies 20 ·
