Infinite square well, momentum space
In summary, the momentum-space wave function for the nth stationary state of the infinite square well is given by Phi_n(p,t) = \frac{\phi_n(t)}{\sqrt{a\pi\hbar}} \int^{\infty}_{-\infty} e^{-ipx/\hbar} \sin(\frac{n\pi}{a}x) dx.
NeoDevin
334
Problem:
Find the momentum-space wave function [itex] \Phi_n(p,t)[/itex] for the [itex]n[/itex]th stationary state of the infinite square well.
Equations:
[tex] \Psi_n(x,t) = \psi_n(x) \phi_n(t) [/tex]
[tex] \psi_n(x) = \sqrt{\frac{2}{a}}\sin(\frac{n\pi}{a}x) [/tex]
[tex] \phi_n(t) = e^{-iE_n t/\hbar} [/tex]
[tex] \Phi_n(p,t) = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{-ipx/\hbar} \Psi_n(x,t) dx [/tex]
Attempt:
[tex] \Phi_n(p,t) = \frac{\phi_n(t)}{\sqrt{a\pi\hbar}} \int^{\infty}_{-\infty} e^{-ipx/\hbar} \sin(\frac{n\pi}{a}x) dx [/tex]
[tex] = \frac{\phi_n(t)}{\sqrt{a\pi\hbar}} \frac{1}{2i} \int^{\infty}_{-\infty}\Bigg(e^{i(\frac{n\pi}{a} - \frac{p}{\hbar})x} - e^{i(\frac{-p}{\hbar} - \frac{n\pi}{a})x}\Bigg) dx [/tex]
[tex] = \frac{\phi_n(t)}{\sqrt{a\pi\hbar}} \frac{1}{2i} 2\pi \Bigg(\delta(\frac{n\pi}{a} - \frac{p}{\hbar}) - \delta(\frac{p}{\hbar} + \frac{n\pi}{a})\Bigg) [/tex]
This doesn't seem right to me. Do I have this right, or am I missing something somewhere?
OOOOPS. Except you DON'T want to integrate x from -infinity to +infinity. The wavefunction only lives in the box.
Oh, right... thanks
I corrected my previous flip answer.
I know, I saw. Thanks.
He SHOULD integrate from - to + infinity, it's just that outside the box the wavefunction is strictly 0...
What happens when you only integrate from 0 to a? When I try I get a seemingly uselessly messy answer, is there some trick to use delta functions or something I am missing?
Hi, See Schbert
http://www.ecse.rpi.edu/~schubert/Course-ECSE-6968%20Quantum%20mechanics/Ch03%20Position&momentum%20space.pdf
Regards.
FAQ: Infinite square well, momentum space
What is an infinite square well potential?
An infinite square well potential is a theoretical model in quantum mechanics that describes a particle confined to a finite region with an infinitely high potential energy barrier at the boundaries. This potential is often used to study the behavior of particles in one-dimensional systems.
How does the infinite square well potential affect the energy levels of a particle?
The infinite square well potential creates discrete energy levels for the particle, meaning that the particle can only have certain energies within the well. These energy levels are quantized and can be found using the Schrödinger equation.
What is momentum space in the context of the infinite square well?
Momentum space in the context of the infinite square well refers to the representation of the particle's wavefunction in terms of its momentum. This representation is often used to better understand the behavior of the particle and can be found by taking the Fourier transform of the wavefunction in position space.
How does the momentum space representation of the wavefunction relate to the position space representation?
The momentum space representation of the wavefunction is related to the position space representation through a mathematical transformation called the Fourier transform. This transformation allows us to switch between representations and gain insight into the behavior of the particle in both position and momentum space.
What is the Heisenberg uncertainty principle in the context of the infinite square well potential?
The Heisenberg uncertainty principle states that there is a fundamental limit to how precisely we can know both the position and momentum of a particle at the same time. In the context of the infinite square well potential, this means that the more we know about the position of the particle, the less we know about its momentum, and vice versa.
