Brian-san
- 45
We have an infinite square well potential of width 2L centered at the origin, with an attractive delta function potential V0δ(x) at the origin, with the properties
[tex]V_0<0, -V_0>\frac{\hbar^2}{mL^2}[/tex]
Determine the conditions for a negative energy bound state.
There are a few other parts to the question, but I do not have the sheet at the moment.
Schrodinger Equation
In the absence of the delta function, we get
[tex]-\frac{\hbar^2}{2m}\frac{\partial^2\psi}{\partial x^2}=E\psi[/tex]
This differential equation has character polynomial given by
[tex]x^2+\frac{2mE}{\hbar^2}=0, x=\pm\frac{i\sqrt{2mE}}{\hbar}[/tex]
The solution is then
[tex]\psi=Asin\left(\frac{\sqrt{2mE}}{\hbar}x\right)+Bcos\left(\frac{\sqrt{2mE}}{\hbar}x\right)[/tex]
Using the boundary condition that the wave function is zero at ±L and normalizing the wave function, I get
[tex]\psi=L^{-\frac{1}{2}}cos\left(\frac{n\pi x}{2L}\right), L^{-\frac{1}{2}}sin\left(\frac{n\pi x}{2L}\right)[/tex]
Where the cosine solution is for odd n and the sine solution is for even n. Also, the energy spectrum is given by
[tex]E_n=\frac{n^2\pi^2\hbar^2}{8mL^2}[/tex]
For any positive integer n. This is the solution for the infinite well without the delta function, the full Schrodinger equation should be
[tex]-\frac{\hbar^2}{2m}\frac{\partial^2\psi}{\partial x^2}+V_0\delta(x)\psi=E\psi[/tex]
I thought about integrating both sides over the width of the well to eliminate the delta function and get
[tex]-\frac{\hbar^2}{2m}\int_{-L}^{L}\frac{\partial^2\psi}{\partial x^2}dx+V_0\psi(0)=E\int_{-L}^{L}\psi dx[/tex]
For even n this is trivial, but for odd n it seems to give me that V0=0, which is not true, nor very helpful. Obviously the bound state will most likely be the ground state n=1, so I thought it could be
[tex]E_1<-V_0, \frac{\pi^2\hbar^2}{8mL^2}<-V_0[/tex]
However, I have a feeling that I am supposed to work in the conditions imposed on V0 somehow. Is the work so far on the right track, or have I missed something important? There are a few more parts to the question, but this is all I could remember without the sheet near me.
