Infinite sum of non negative integers
In summary: Good job! In summary, for the given sequence of non-negative integers, options B and E cannot be true.
matrixone
28
Consider a sequence of non negative integers x1,x2,x3,...xn
which of the following cannot be true ?
##A)\sum ^{\infty }_{n=1} x_{n}= \infty \space and \space \sum ^{\infty }_{n=1} x_{n}^{2}= \infty##
##B)\sum ^{\infty }_{n=1} x_{n}= \infty \space and \space \sum ^{\infty }_{n=1} x_{n}^{2}< \infty##
##C)\sum ^{\infty }_{n=1} x_{n}< \infty \space and \space \sum ^{\infty }_{n=1} x_{n}^{2}< \infty##
##D)\sum ^{\infty }_{n=1} x_{n} \leq 5 \space and \space \sum ^{\infty }_{n=1} x_{n}^{2} \geq 25##
##E)\sum ^{\infty }_{n=1} x_{n}< \infty \space and \space \sum ^{\infty }_{n=1} x_{n}^{2}= \infty##
A) is true when xn = n
B)
C) is true when xn = 1/n
D)
E)
i can't find any ways to eliminate or finalise B,C, or D
Hi,
Let's work our way down the list. You did A already. Then:
If ##x\ge1##, what do you know about ##x^2## in relation to ##x## ?
B)
D)
E)
It says the sequences are integers. ##1/n## is not an integer.
Hadn't even considered that ! was too focused on the fact that ##
C)\sum ^{\infty }_{n=1} x_{n}\nless \infty## for 1/n
BvU said:
Hi,
##x^2 \geq x## and the equality is only when x=1
So in no case the sum of ##x_{n}## can exceed ##x_{n}^{2}##
So B cannot be true .
Am i correct Sir ?
I never noticed that SIr ! thanks for pointing out ...
if both the sequence contains only zeroes this is true ...
So C is also eliminated.
For D,
Lets have first sequence : 5,0,0,0,0,0,...
So second sequence : 25,0,0,0,0,0,...
So it is possible .
for E,
Only case where the first sum is less than infinity is finite number of positive terms. In that case second sum will also be finite.
So E is also true
So final answers B and E ?
Am i correct now ?
Thanks a lot both of you :)
Am i correct Sir ?
For D,
So it is possible .
for E,
So E is also true
Am i correct now ?
Looks like you've got it.
FAQ: Infinite sum of non negative integers
What is an infinite sum of non-negative integers?
An infinite sum of non-negative integers is a mathematical series where the terms are non-negative whole numbers and the number of terms in the series is infinite. The sum of the series is also infinite.
What is the formula for calculating the infinite sum of non-negative integers?
The formula for calculating the infinite sum of non-negative integers is S = 1 + 2 + 3 + 4 + ..., where S represents the sum and the terms are consecutive positive integers.
Can the infinite sum of non-negative integers be solved?
No, the infinite sum of non-negative integers cannot be solved as it is an infinite series and its sum is also infinite. However, the sum of a finite number of terms can be calculated.
What is the value of the infinite sum of non-negative integers?
The value of the infinite sum of non-negative integers is undefined as it is an infinite series. However, as more terms are added, the sum will approach infinity.
What is the significance of the infinite sum of non-negative integers in mathematics?
The infinite sum of non-negative integers is a fundamental concept in mathematics and is used in various branches such as calculus, number theory, and analysis. It also has applications in real-life situations, such as calculating probabilities and finding the area under a curve.
