Infinitely smaller changes in a related rates question
In summary, the conversation discusses related rates problems and how the area of a circle changes with respect to time. It is shown that as time increases, the area increases at a constant rate and the radius increases as the square root of that rate. The conversation also mentions the physical significance of the area changing at a constant rate and the derivative of r as a decreasing function. However, it is suggested that the OP should consider the proportional relationship between r and t and the lack of an upper limit for r.
NoahsArk
24
I was looking at related rates problems, and the problem of finding the rate at which the area of a circle changes with respect to time. In order for the area of a circle to be changing at a constant rate, say per second, it would have to mean that the radius was increasing by a smaller and smaller amount each second. In that case, can the area continue changing by the same amount each second for an infinite amount of time?
You could answer this yourself by considering the equation:
##area(t) = A * t = \pi * r^2## where A is some constant rate of change in a area per second units.
solve for r as a function of t.
What do you see for r as t increases? You could plot it via the desmos online calculator at:
www.desmos.com/calculator
In the examples given, we already know the change in the radius per second, and are asked to find the instantaneous rate of change of the area at a given time. This part I can do, but was wondering what the physical significance would be of the area changing at a constate rate. If I'm not mistaken, it would have to mean that the radius was increasing by a lesser and lesser amount each second.
Yes and I provided you with a means to answer it.
So what do you see?
r is dependent on the square root of time so at one second r is 1 at 2 secs r is 1.414 at 10 secs r is 3.162 and at 100 secs r is 10.
I will think about it and write back. Thanks.
Likes Delta2
What’s there to think about?
As time increases, the area increases at a constant rate and r increases as square root of that rate meaning there is no limit for r increasing even the rate of increase gets smaller and smaller to zero.
## A * t = \pi * r^2 ##,
## r^2 = \frac {A * t} {\pi} ##
## r = \sqrt \frac {A * t} {\pi} ##
Is this what you meant by solving for r as a function of t?
Likes Delta2 and jedishrfu
yes, so the equation tells you how r evolves relative to t.
r is proportional to the square root of t
Likes NoahsArk
Its not crystal clear that the rate of increase of r is a decreasing function. For this to be crystal clear we have to consider the derivative ##r'(t)## and show that it is indeed a decreasing function. Nothing too hard but just saying...
Likes jedishrfu
This was in response to the OP saying he'll think about it and get back that's code for saying I'm moving on to the next problem and will let this one slide.
I was hoping the OP would notice that r is proportional to the square root of t and that there is no upper limit for r just that the change in r gets smaller and smaller as opposed to writing r in terms of t and not thinking any deeper.
FAQ: Infinitely smaller changes in a related rates question
What is a "related rates" question?
A related rates question is a type of problem in mathematics or physics that involves finding the rate of change of one quantity with respect to another related quantity. This can often involve finding the rate of change of a variable over time.
What does it mean for a change to be "infinitely smaller" in a related rates question?
In a related rates question, "infinitely smaller" refers to the concept of taking a limit as the change in one quantity approaches zero. This allows for a more precise calculation of the rate of change between two related quantities.
Why are infinitely smaller changes important in related rates problems?
Infinitely smaller changes are important in related rates problems because they allow for a more accurate and precise calculation of the rate of change between two related quantities. This can be especially useful in real-world situations where small changes can have a big impact.
What are some common examples of related rates problems?
Examples of related rates problems can include finding the rate of change of the volume of a balloon as it is being inflated, the rate of change of the length of a shadow as the sun moves, or the rate of change of the distance between two moving objects.
What are some strategies for solving related rates problems involving infinitely smaller changes?
Some strategies for solving related rates problems involving infinitely smaller changes include identifying the related quantities and their rates of change, setting up a mathematical equation that relates the two quantities, and then taking the derivative with respect to time to find the rate of change. It is also important to carefully consider the units and use appropriate units throughout the problem.
