Infinitesimal conformal transformations
Yes, your last comment is correct. Let's say we have a set of massless states, labeled by the ##W^2## values. As you wrote, ##[P^2,D]## is a Hermitian operator (since its part of the Poincare algebra) that acts on that Hilbert space. If we start with a state with a particular ##W^2## label, then ##P^2## is a C-number that is specified by the label.Now, of course, the commutator will give a new state with some label. But we know that the new state can't have a different ##P^2## because
CAF123
88
Find the infinitesimal dilation and conformal transformations and thereby show they are generated by ##D = ix^{\nu}\partial_{\nu}## and ##K_{\mu} = i(2x_{\mu}x^{\nu}\partial_{\nu} - x^2\partial_{\mu})##
The conformal algebra is generated via commutation relations of elements of the set ##\left\{P_{\mu}, D, L_{\mu \nu}, K_{\mu}\right\}##. Write down the non vanishing commutation relations for the comformal group given that ##P_{\mu} = i\partial_{\mu}## and ##L_{\mu \nu} = i(x_{\nu}\partial_{\mu} - x_{\mu}\partial_{\nu})##, Hence show that ##P^2## is no longer a Casimir operator and thus that only massless theories can be conformally invariant.
2. Homework Equations
##x'^{\mu} = \alpha x^{\mu}## for finite dilations and ##x'^{\mu} = \frac{x^{\mu} - x^2b_{\mu}}{1-2x_{\mu}b^{\mu} +b^2x^2}## for finite CT's.
Write an infinitesimal dilation transformation as ##x'^{\mu} = e^{\Lambda}x^{\mu} = (1+i\alpha D)x^{\mu}## where D is the dilation generator and alpha some infinitesimal scaling. Alternatively, by taylor expanding to first order, ##x'^{\nu} = x^{\nu} + x^{\mu}\partial_{\mu}x^{\nu}##. Comparison with the previous result gives ##D = ix^{\mu}\partial_{\mu}##. Is that ok?
Similarly, for CT's, ##x'^{\mu} = (1+i\alpha^{\rho} K_{\rho})x^{\mu} = x^{\mu} + 2x^{\mu}(b \cdot x) - x^2b^{\mu}##. But if I identify lhs and rhs here I don't get any derivative terms appearing?
And to check my reasoning for the last part: P^2 is not a casimir operator for the conformal algebra anymore because it doesn't commute with D. (A casimir must commute with all the algebra generators). I am not really sure how to show that massless theories must be conformally invariant given the fact that ##P^2## is not a casimir, so a hint here too would be great. Thanks!
You can also use the general formula for a generator, involving differentiation of the new coordinates by the group parameter, and then evaluating at the identity. E.g., for your dilation transformation, it is
$$D ~=~ \left. \frac{\partial x'^\mu}{\partial \alpha} \right|_{\alpha=1} ~ \frac{\partial}{\partial x^\mu}$$ You might want to re-express the dilation as ##x'^{\mu} = e^\alpha x^{\mu}## so that the identity corresponds to ##\alpha=0## rather than ##\alpha=1##.
I leave it to you to generalize this to the case of multiple group parameters (which is required to find the SCT generator). :oldbiggrin:
BTW, it should be ##b^\mu## in the SCT numerator.
Re the final part: consider how a representation with ##P^2=0## changes under a dilation... :oldwink:
Hi strangerep, many thanks I see the first part. Hmm if ##P^2=0## and I consider ##[P^2, D]## then this is identically zero. But I can also expand as ##P^{\mu}[P_{\mu},D] + [P_{\mu},D]P^{\mu} = 2iP^2 = 0##. But how does this tell us about conformal invariance?
It's only zero if you act with that operator on a state vector in the Hilbert corresponding to a zero-mass field. So you should probably include a state vector in your statements.
Have you studied how (ordinary) QFT is constructed by finding the unitary irreducible representations of the Poincare group? This is done in Weinberg vol1, and also (iirc) Hendrik van Hees's QFT notes. The idea is to construct a Hilbert space which "carries a representation" of the Poincare group (meaning the elements of the group are represented faithfully by operators on that Hilbert space).
To perform such a construction, one first finds the Casimirs of the group. (For Poincare, these are the mass and total angular momentum.) The Casimirs are important because if we choose a field with specific values of those Casimirs, then other Poincare group elements won't change those values.
But this is a rather long (but very important) story. You might want to start a thread about it in the main QM forum.
Consider a Hilbert space consisting of states of a massless field. Dilations will simply map these states among themselves. In this sense, that Hilbert space "carries a representation" of dilations.
In contrast, for the Hilbert space of a massive field, those dilations will map out of the Hilbert space (since they change the mass). Therefore, that Hilbert space does not carry a representation of dilations.
Ok, so I would write ##[P^2, D]|P^2, W^2\rangle = 2iP^2 |P^2, W^2\rangle## where ##P^2## and ##W^2## are the Casimir operators of the Poincare group and as such as can label states. Extending to dilations, we see that the r.h.s of the above is not identically zero so ##P^2## is no longer a viable Casimir operator for the conformal group (which contains dilations). Is this better?
If the states are all massless then ##P^2=0## and so ##[P^2,D]|P^2=0, W^2\rangle = 0 \cdot |P^2=0, W^2\rangle##. All we know at this stage is that the state we get back is a massless state but to characterise what massless state it actually is we require knowledge of ##W^2## obtained by the action of ##W^2## on the state. Is this what you meant by saying the massless states transform amongst themselves? Thanks!
I would have used different symbols to label the states, e.g., ##|m,j\rangle##. In that notation, $$P^2|m,j\rangle = m^2 |m,j\rangle ~.$$ (##m,j,## are numbers, whereas ##P^2, W^2## are operators.)
If the states are all massless then ##P^2=0## and so $$[P^2,D]|P^2=0, W^2\rangle = 0 \cdot |P^2=0, W^2\rangle$$. All we know at this stage is that the state we get back is a massless state but to characterise what massless state it actually is we require knowledge of ##W^2## obtained by the action of ##W^2## on the state. Is this what you meant by saying the massless states transform amongst themselves?
I meant the following: let ##H_m## be a Hilbert space of states carrying a representation of the Poincare group corresponding to a field of mass ##m##. Then (by definition), for every ##\psi\in H_m##, we have $$P_\mu\psi\in H_m ~,~~~~ J_{\mu\nu}\psi\in H_m ~,$$ and, of course, $$P^2 \psi\in H_m ~.$$ However, for ##m\ne 0##, then $$\phi ~:=~ D\psi \notin H_m ~,$$ but for ##m=0## we have $$\chi ~:=~ D\psi \in H_0 ~.$$
Ok, I see, so you just used the eigenvalues of the operators to label the states like it is done in quantum mechanics.
So this is the statement I need to prove to answer the question, yes?
##P^2|m,j\rangle = m^2|m,j\rangle## and ##[P^2, D]|m,j\rangle = 2iP^2|m,j\rangle=2im^2|m,j\rangle##. So if ##m=0## then ##P^2## is still a Casimir of the conformal group (provided it also commutes with SCT generator). So its eigenvalues (=0) can be used to label states living in a Hilbert space carrying a representation of the conformal group and these massless states within a representation are distinguished by the action of another Casimir operator onto the state which determines it uniquely. Is this right and enough to answer the question?
If it is right, then that would mean ##D|m=0,j\rangle = |m=0,j'\rangle## (i.e action of D produces a massless state but this state need not be the same from the one denoted by j).
Then if also, ##[D,W^2]=0## then ##D|m=0, j \rangle = |m=0,j\rangle## i.e state is invariant.
Is any of that ok? Hope I'm getting there :)
I hope so. (Tbh, I'm not entirely sure how much the question expects from you.)
##P^2|m,j\rangle = m^2|m,j\rangle## and ##[P^2, D]|m,j\rangle = 2iP^2|m,j\rangle=2im^2|m,j\rangle##. So if ##m=0## then ##P^2## is still a Casimir of the conformal group [...]
Your terminology is not quite right. You'd have to say a bit more, like: "##P^2## is still a Casimir of the conformal group if restricted to the massless sector".
As I read the question, it's not really asking you about the other eigenvalues, but only about the mass eigenvalue.
If it is right, then that would mean ##D|m=0,j\rangle = |m=0,j'\rangle## (i.e action of D produces a massless state but this state need not be the same from the one denoted by j). Then if also, ##[D,W^2]=0## then ##D|m=0, j \rangle = |m=0,j\rangle## i.e state is invariant
Again, I'm not sure you need to be specific about the other eigenvalues. You could just write ##|m=0,\; \dots\rangle##
Likes CAF123
Ok, many thanks. Does this imply then that a massless theory need not be conformally invariant only that for a theory to be conformally invariant it must be a massless theory? What we've shown above is that massless theories are invariant under dilations (the action of dilations is just to mix between different states of the representation) and since dilations are part of the conformal group, conformal invariance in massless sector would need dilation invariance in the massless sector.
Thanks!
I guess so. What really matters is the maximal dynamical group for the (class of) system(s) being considered.
Or we're dealing with a rather weird case that admits a continuous spectrum of nonzero masses. But I don't know any of those.
Yes, that's the idea. BTW, to complete the picture you might want to check what happens with SCTs.
[Aside:] I'm not very happy with the term "conformally invariant theory", since it's not always clear what is meant thereby. I prefer to think about the maximal dynamical group for the system -- by which I mean the maximal group which preserves the equations of motion, i.e., which maps solutions into solutions. This is easy enough to understand in the classical case. In the quantum case, it means we require a Hilbert space carrying a representation of the group.
But this perspective gets lost in the voluminous reams of material about Lagrangians, etc. It doesn't hurt to be aware that the Lagrangian+Noether approach might not always tell the whole story -- at least, not without some extra work. E.g., for the ordinary classical Kepler problem there's an extra time-dependent dynamical symmetry of the equations of motion which does not correspond to a conserved quantity. Nevertheless, that symmetry is the underlying reason for Kepler's 3rd law, and hence is reasonably important .
Likes CAF123
Related to Infinitesimal conformal transformations
What are infinitesimal conformal transformations?
Infinitesimal conformal transformations are mathematical operations that involve changing the scale and orientation of a geometric object while preserving its shape. They are a type of transformation used in the field of conformal geometry, which studies the properties of objects that are preserved under these types of transformations.
What are some examples of infinitesimal conformal transformations?
Some common examples of infinitesimal conformal transformations include rotations, translations, and dilations. These operations can be applied to various types of geometric objects, such as lines, circles, and polygons, to produce new objects that are congruent to the original.
How are infinitesimal conformal transformations used in science?
Infinitesimal conformal transformations are used in many areas of science, including physics, engineering, and computer graphics. In physics, they are used to study the behavior of physical systems that exhibit conformal symmetry, such as electromagnetism and fluid dynamics. In engineering, they are used to model and analyze complex structures and systems. In computer graphics, they are used to create realistic and visually appealing 3D models and animations.
What are the applications of infinitesimal conformal transformations?
The applications of infinitesimal conformal transformations are vast and diverse. They are used in fields such as differential geometry, symplectic geometry, and Lie theory, to name a few. In addition, they have practical applications in fields such as robotics, control theory, and image processing. They also have important applications in theoretical physics, particularly in string theory and other areas of theoretical physics that involve the study of symmetries and invariants.
What are some challenges associated with infinitesimal conformal transformations?
One of the main challenges associated with infinitesimal conformal transformations is their mathematical complexity. These transformations involve highly abstract concepts and can be difficult to understand and apply without a strong background in mathematics. In addition, there are still many open questions and unsolved problems in the field of conformal geometry, making it an active area of research for mathematicians and scientists alike.
