Infinitesimal transformation of a field
In summary, an infinitesimal transformation of a field is a small, continuous change in the values or properties of a field, often used in physics to describe the behavior of a system over time. It is different from a finite transformation in that it involves a very small change in the field. Examples of fields that undergo infinitesimal transformations include electric and magnetic fields, gravitational fields, and quantum fields. Infinitesimal transformations are significant in physics as they allow for a more precise and accurate understanding of a system's behavior. However, there are limitations to their use, such as in systems with discontinuous changes and the assumptions made may not always hold true in complex systems.
marcom
Hi,
Could you please explain me why, under the transformation of a complex valued field Φ→eΦ, for an infinitesimal transformation we have the following relation?
δΦ=iαΦ
Thanks a lot
marcom said:
Hi,
δΦ=iαΦ
Thanks a lot
When [itex]\alpha[/itex] is infinitesimal, i.e. [itex]\alpha^{2} = 0[/itex], you can write [itex]e^{i\alpha} = 1 + i\alpha[/itex]. So, [itex]\Phi \to \Phi^{'} = \Phi + i\alpha \Phi[/itex], leads to [itex]\delta\Phi = \Phi^{'} - \Phi = i\alpha \Phi[/itex].
Likes HallsofIvy and bhobba
FAQ: Infinitesimal transformation of a field
What is an infinitesimal transformation of a field?
An infinitesimal transformation of a field is a small, continuous change in the values or properties of a field. It is often used in physics to describe the behavior of a system over time.
How is an infinitesimal transformation of a field different from a finite transformation?
An infinitesimal transformation involves a very small change in the field, while a finite transformation involves a larger, more significant change. Infinitesimal transformations are often used in physics because they allow for a more precise and accurate description of the behavior of a system.
What are some examples of fields that undergo infinitesimal transformations?
Some examples of fields that undergo infinitesimal transformations include electric and magnetic fields, gravitational fields, and quantum fields.
What is the significance of infinitesimal transformations in physics?
Infinitesimal transformations are essential in physics because they help us understand how a system changes over time. They allow us to study the behavior of a system in small increments, which can then be used to make predictions about its behavior in larger increments.
Are there any limitations to using infinitesimal transformations in physics?
While infinitesimal transformations are a powerful tool in physics, there are some limitations to their use. For example, they may not be applicable in systems with discontinuous or abrupt changes. Additionally, the assumptions made in using infinitesimal transformations may not always hold true in complex systems.
