Infinity at the Center of the Galaxy
In summary, New observations from the Herschel Space Observatory have revealed a strange, twisted ring of dense gas at the center of our Milky Way galaxy. This ring, which is in the plane of our galaxy, appears to have an infinity symbol shape with two lobes pointing to the side. However, astronomers have determined that the ring is actually torqued in the middle, giving it the appearance of two lobes. This ring is estimated to be 600 light years across, while the black hole at the center of our galaxy (known as Sagittarius A*) is only 17 light hours across, making it too small to be resolved in an image of the entire ring. According to observations and models, there is a super massive black
Dotini
231
"Infinity" at the Center of the Galaxy
http://www.sciencedaily.com/releases/2011/07/110719151234.htm
http://www.wired.com/wiredscience/2011/07/milky-way-ribbon/
New observations from the Herschel Space Observatory show a bizarre, twisted ring of dense gas at the center of our Milky Way galaxy...Astronomers were shocked by what they saw -- the ring, which is in the plane of our galaxy, looked more like an infinity symbol with two lobes pointing to the side. In fact, they later determined the ring was torqued in the middle, so it only appears to have two lobes.
According to Wikipedia and National Geographic, there is a massive black at the center of our galaxy at Sagittarius A. Yet there is no Sagittarius A or black hole shown in the Herschel observations that I can see. Are there now to be two centers of our galaxy? What happened to the black hole? Lost, stolen, dissolved or never there to begin with? Do other spiral galaxies work like ours does? I suspect that they do.
Respectfully submitted,
Steve
Astronomy news on Phys.org
The ribbon shown is 600 light years across. The black hole is estimated to be no larger than 17 light hours across, that is 1/309176 the size of the ribbon. It is there, it is just way too small to be resolved in an image that shows that whole ribbon.
Later in the first article linked it is noted
"... Astronomers say that the center of the torqued portion of the ring is not where the center of the galaxy is thought to be, but slightly offset. The center of our galaxy is considered to be around "Sagittarius A*," where a massive black hole lies. According to Noriega-Crespo, it's not clear why the center of the ring doesn't match up with the assumed center of our galaxy. ..."
Steve
Sometimes this thought comes to my mind.
As our technology improves, as we see more and more of the center clearly, and find there is no 'black hole' in there as prescribed. And that motions of surrounding stars orbiting the center can be explained by other objects around, what would be the reactions of astronomers, astrophysicists?
Will they search for black holes somewhere else? Will they insist there's a black hole at the center which changed because of aging? etc.
Why have this thought?
(If they see more an more clearly and find there is a stuffed panda bear at the centre, what would their reactions be?)
It sounds like you think they're clinging to a theory that is becoming increasingly unsupported by observations and models. Why do you think this?
Because we know so very little about the universe, there are so many unknowns, so many variables, our current theories satisfy the objects we know exist. I think the thought behind my question was how would our theories change when objects we didn't know exist were discovered?
We didn't even know Neptune (or Uranus?) has rings like Saturn until a close encounter by a probe. We didn't even know until recently a small rock is tagging along with the earth. So many surprises await us, only time will tell.
The observations say unequivably that there HAS to be a super massive object at the center of the galaxy. There is no other explanation for the observed motion of the stars at the center. The size of the object is much less well known so you could argue that it isn't a black hole but just something super-massive. Problem with that is that the gravity would MAKE it a black hole if it weren't already.
So you can hypothesize all you want but it isn't going to change the fact that there is a super massive black hole at the center of the galaxy.
If you think this, you clearly have not studied the data. Look at this paper, especially Figures 13 and 16:
http://arxiv.org/abs/0810.4674v1
There are a large number of stars orbiting the central black hole whose orbits have been determined to high accuracy. One of them (Figure 13) has even been plotted around an entire orbit. All it takes is Kepler's laws to determine the mass of the object around which they are orbiting - about 4 million times the mass of the sun. So there is clearly a very massive object around which the stars are orbiting, and this object is invisible. Since Einstein's theory has been tested to high accuracy and has always agreed with experiment, and since it predicts the existence of black holes, we believe this massive, invisible object is in fact a black hole. What else would you suppose it be? How can this be explained by "other objects around"? What "other objects"?
http://www.astro.cornell.edu/academics/courses/astro201/rotation_flat.htm
Does this have anything to do with it?
Steve
Steve
In a word, no. This graph is showing the rotation speed of objects very far from the center of the galaxy. This graph refers to the galaxy UGC 9242, which is 66 million light-years away. So the first point, at ~1 arcsec from the center, represents the rotation speed of the closest stars measured, which are about 300 light years from the center of this galaxy. By comparison, the images of the stars orbiting the center of the Milky Way galaxy are about .01 light years from the center of the galaxy - vastly closer. We are looking at two very different things.
phyzguy said:
...the images of the stars orbiting the center of the Milky Way galaxy are about .01 light years from the center of the galaxy...
600 or 0.01? Who's right?
Steve
Steve
It seems that you are not paying any attention to the posts in this thread. The figure of 600 is the diameter of the infinity thingy in light years. The figure of .01 is the diameter in light years of the orbit of the innermost stars that have been observed circling the black hole. The two have absolutely nothing to do with each other.
I note that you are not responding to the comments on your odd disbelief about the black hole.
Very sorry, sir. I respectfully would like to point out that I did not realize that there were comments directed toward me. I thought they were to Neandethal00. I personally don't know enough to hold beliefs, only doubts and questions.
Could I implore a kind-hearted mentor to display the twisted ring image, please? My computer skills are obviously commensurate with my knowledge of astronomy. I'm recently retired from Boeing, and I'm here trying to politely participate and learn something. I appreciate your patience and forbearance.
Steve
You linked to them in post 1...
Very well...
I submit that it is not in fact an infinity symbol, but a Moebius strip, with a chiral handedness that reflects the predominance of matter vs. antimatter in our galaxy. I wonder what astronomers and astrophysicists will think when additional evidence demonstrates that I am correct. :smile:
Very well...
It's neither. As the article points out, it is a ring that is slightly twisted, viewed edge on.
I think he was kidding.
(but it being a ring doesn't negate it being a Moebius strip :-p - at least geometrically. Physically of course, there are no "faces" so it's meaningless.)
Steve
Ok, you brough me back to this thread. Like you I'm also here to learn by asking questions and expressing doubts.
The question you raised about 600 LY or .01 LY also came to my mind after reading the posts. My immediate assumption was the 'infinity' symbol is at the center of Milky Way, and the closest stars (to the center) are outside the symbol. But from the picture and comments it appears that the 'infinity' symbol stretches over many stars near the center of the galaxy.
I'm not an astronomer, so, I'll accept whatever is found to be true. I can jump ship in minutes, but professional astronomers can't.
Neandethal00:
I'm still not sure that you're getting it. The 'infinity' symbol is in the center of the galaxy, and the ribbon is about 600 light-years wide, like Janus said. The stars in the vicinity of the central black hole which have been used to determine the mass of the black hole are only 0.01 light-years from the center - i.e. that region is a tiny dot in the middle of this picture that is too small to see at this scale. The event horizon of the central black hole itself is about 25 million km across, or about 0.000002 light-years, and is too small to be seen in even our largest telescopes, although there are programs underway that should be able to resolve the event horizon of the central black hole using a world-spanning network of radio telescopes (VLBI) in the next few years.
You didn't answer the questions as to why you doubt the existence of the central black hole.
phyzguy said:
Neandethal00:
He did answer them. He explained that he misunderstood and made some assumptions.
He thought what he thought because he thought the infinity was smaller than the stars. Now that he's been enlightened that the infinity is vastly larger than the very centre point, he sees his mistake.
He thought that he thought because he thought the infinity was smaller than the stars. Now that he's been enlightened that the infinity is vastly larger than the very centre point, he sees his mistake.
Ah, I see now. Sorry, I missed that. Thanks.
in this discussion, what i find disturbing is the fact that there are still those out there who, for what ever reason, are starting with a premise and looking to explain it whether or not the facts support the premise. If not, then the test is wrong, not the premise. You can't ask the questions to arrive at your solution, you must ask the questions and follow the answers to discover "truth". Other wise why not just say the world is flat, Earth is the center of the known universe and stay home!
all information is good, putting it in context gives us knowledge!
Who's doing that?
DaveC426913 said:
Who's doing that?
if i misread it, sorry, i thought that "Neandethal00" was
You didn't follow the whole thread I think. He was drawing conclusions on what he thought was correct evidence. When his errors about the evidence were corrected, he realized the error in his conclusion (post 18).
My immediate assumption was the 'infinity' symbol is at the center of Milky Way, and the closest stars (to the center) are outside the symbol. But...
:blushing:
sorry
Related to Infinity at the Center of the Galaxy
1. What is "Infinity at the Center of the Galaxy"?
"Infinity at the Center of the Galaxy" is a scientific concept that refers to the idea that the center of our galaxy, the Milky Way, contains a supermassive black hole with infinite density and gravitational pull.
2. How do we know there is a supermassive black hole at the center of the galaxy?
Scientists have observed the movement of stars and gas around the center of the galaxy and have found that they are orbiting around an invisible object with an extremely strong gravitational pull. This object is most likely a supermassive black hole.
3. What are the implications of having "Infinity at the Center of the Galaxy"?
The existence of a supermassive black hole with infinite density at the center of our galaxy has significant implications for our understanding of gravity and the laws of physics. It also has a major influence on the formation and evolution of galaxies and the universe as a whole.
4. Is "Infinity at the Center of the Galaxy" dangerous for Earth?
No, the supermassive black hole at the center of the galaxy is located approximately 26,000 light-years away from Earth, making it too far to have any direct effects on our planet. However, its gravitational pull does play a crucial role in keeping the galaxy together.
5. Can we ever reach "Infinity at the Center of the Galaxy"?
No, it is not possible for humans or any spacecraft to physically reach the supermassive black hole at the center of the galaxy. Its immense gravity would crush anything that gets too close, and the extreme conditions would make it impossible for any known material to survive.
  • Astronomy and Astrophysics
27K
