Infinity Numbers (Expanded P-Adic Numbers)
  • I
  • Thread starter Lokalgott
  • Tags
    Infinity
In summary, "Infinity Numbers (Expanded P-Adic Numbers)" explores the concept of expanded p-adic numbers, which extend the traditional p-adic number system. These numbers incorporate a broader range of values, allowing for a more comprehensive understanding of number theory and mathematical analysis. The work delves into their properties, applications, and implications in various mathematical contexts, highlighting their significance in both theoretical and practical domains.
Lokalgott
Hello,
I'm new here and I'm looking to talk about p-adic numbers.
It's not a specific school problem .
I'm trying to expand p-adic numbers into something that I call "Infinity Numbers".
Is it possible here to discuss topics like that?
Kind regards
Lokalgott said:
Hello,
Kind regards
Only if it is a part of an existing canon of math, with published articles on the subject (published in reputable journals). If it is a personal theory, then no. And by the way, your introduction post is supposed to be in the introduction section. Good idea to read the rules.
Likes topsquark
Lokalgott said:
Hello,
Why don't you call it what everyone else calls it?
Kind regards
If you give enough details. Right now it is completely unclear what you want to discuss.
I want to talk about the arithemtics of p-adic numbers:
Check this video - introduces the stuff I want to talk about:
P-Adic Numbers - Interactions
Kind regards
You can discuss p-adic numbers.
Kind regards
I haven't watched it, i'd say just talk about what you want to talk about.
Likes phinds
Well if you watch it then you know what I'm talking about so it might be more difficult for you to understand then
I'd like to have people who dealt with the arithmetics of p-adic numbers because then it's more easy for me and for them more easier to follow my thoughts.
But I want to talk about these arithmetics from p-adic numbers.
Is there a formula editor here so that I can show more easy what I mean?
First off I want to talk about the transformation of the geometric progression
f(x)= 1+x^1+x^2+x^3+x^inf = 1/(1-x)
First off:
I want to talk about that numbers x>1 do make sense
Like if you insert x=10
I say that
f(10)=11111..111...=-1/9 makes sense
And second off:
I want to talk about that numbers like
f(10)=111111..111...
and
9*f(10)=99999...999...
are not just the same infinity instead they are different numbers
and actually are equivalents to these numbers that you get when inserting them into
1/(1-x)
so for
f(10)=1/(1-10) =-1/9
and for
9*f(10)=9* 1/(1-10)=-1
So these infinite numbes can turn out to be some form of negative numbers?
What do you and others think of that?
Best regards
Thread closed temporarily for Moderation...
After a Mentor discussion, the thread is reopened provisionally.
I just now sent you a Private Message (PM) with tips on using LaTeX to post equations.
Likes WWGD and fresh_42
I think you should read https://en.wikipedia.org/wiki/P-adic_number.
The problem with p-adic numbers as series ##\sum_{i=k}a_ip^i## with ##k\in \mathbb{Z}## is the convergence. If we only write p-adic numbers as such sums, then it is a purely formal construction. Also a formal construction is ##\dfrac{1}{1-x}= \sum_{i=0}^\infty x^i .## Filling in a number for the variable ##x## and allowing coefficients ##0\leq a_i < p## yields equations like
\ldots + 3\cdot 5^3+3\cdot 5^1+3\cdot 5^{-1}= \ldots 3030_5,3=\overline{30}_5,3=\overline{0_5,3}=-\dfrac{1}{40}_{dec}
in a ##5##-adic notation. The crucial point is
Wikipedia said:
In general, the series that represents a p-adic number is not convergent in the usual sense, but it is convergent for the p-adic absolute value.
The ##5##-adic number ##\overline{0_5,3}=\sum_{i=-1}^\infty a_i 5^i ## with ##a_{2n-1}=3 ## and ##a_{2n}=0## for all ##n\in \{0,1,2,3,\ldots\}## is not convergent in the usual, Archimedean sense. It is a formal construction. In order to converge, we need the ##5##-adic evaluation, the p-adic absolute value. p-adic numbers are the completion of the rational numbers according to the p-adic absolute value. The rational numbers are just specific p-adic numbers. A general p-adic number is difficult (for me) to imagine. But I understand the topological concept of a completion: add all limits of converging series, and consider convergence based on the p-adic absolute value (in order to define what "getting closer and closer, converging" means).
This means: Infinity is not a self-explaining term anymore. You must say what exactly you mean by it.
Likes WWGD and berkeman
Yes I agree. Infinity is not a self-explaining term anymore!
I watched a video and was thinking about that in the following geometric progression the p-adic number ##p## itself
$$ p^0+p^1+p^2+p^\infty$$
always stands for ##-1##
because if you add ##1## to that number all ciphers clap over to ##0##
example
2-adic:
$$ 2^0+2^1+2^2+2^\infty =222...222...$$
$$222...222...+1=1000...000...$$
zeroes everywhere with a ##1## that will never constructed
and since this is zero the infinite p-adic number, here ##222...222...## must be ##-1##
3-adic
$$ 3^0+3^1+3^2+3^\infty =333...333...$$
$$333...333...+1=1000...000...$$
5-adic:
$$ 5^0+5^1+5^2+5^\infty =555...555...$$
$$555...555...+1=1000...000...$$
etc.
Now what about 10-adic?
If I insert ##10## into the geometric progression:
10-adic:
$$ 10^0+10^1+10^2+10^\infty =111...111...$$
$$111...111...+1=111...111...112$$
which this time isn't ##-1##
So since we know that in 10 base system:
$$999...999...=m |*10$$
$$999...999...990=10m$$
substract both equations
$$999...999...999=m
-999...999...990=10m$$
$$9=-9m$$
$$-1=m$$
so
$$m=999...999...=-1$$
We know that:
$$999...999.../9=-1/9$$
$$111...111=-1/9$$
So in base 10:
The geometric progression with p=10 turns out to be ##-1/9## instead of ##-1##
Now I'm asking does that with prime numbers only work to be ##-1## for the geometric progression when you insert ##p## itself?
And does the transformation really gives us also the real value then?
Because if we insert ##10## into
$$ \sum_{n=0}^\infty x^n=1/(1-x)$$
$$1/(1-10)=-1/9$$
We also get that same value we calculated in a different way.
So it seems to be right and maybe true
And for that that in base 10:
Must be
$$-1/9+1=10/9$$
So the other interesting stuff is that on one boundary an infinite number is positive (over ##111...111..##) and on the other side it becomes negative (under ##111...111...112##)
So infinite Numbers include positive and negative numbers and also rationals.
Now you also could express numbers like irrational numbers like ##\pi## inform of infinite numbes . Really funny :biggrin:
  • Sad
Likes weirdoguy
You have some serious problems here!
1) ##p##-adic numbers cannot have powers of ##p## as coefficients.
2) ##p## is prime, so ##p=10## is not allowed.
\dfrac{1}{1-x}=\sum_{n=0}^\infty x^n
is the series expansion around zero. Hence ##x=10## doesn't make sense.
The ##p##-adic numbers are difficult. One has to distinguish numbers from formal expressions, formal expressions from functions, functions from the topological spaces they are defined on, and the topological spaces, in particular ##\mathbb{Q},\mathbb{R},\mathbb{Q}_p## must properly be distinguished.
Read the Wikipedia article, and the English one is in this case far better than e.g. the German one. This is not always the case, but here it is. Another reasonable, because a more professional source would be O'Meara,
Introduction to Quadratic Forms.
It is important that you learn to distinguish between all these concepts. You cannot write
replace ##x## by any number you want, and call this a p-adic number. That's not how it works. I have tried to summarize the concept in
https://www.physicsforums.com/insig...l-number-systems-that-we-have/#p-adic-Numbers
but this cannot replace a good book. And, to be honest, neither can Wikipedia or Veritasium. Especially the latter sells the imagination of understanding, not truly understanding. The English Wikipedia entry on ##p##-adic numbers is not bad. There is also an entry on ##p##-adic analysis, but I haven't checked that one. It is a rather strange branch of mathematics and I didn't want to complicate things further.
If you have problems understanding ##p##-adic numbers, then open a new thread with your questions, but not without providing an answer to the question of what exactly you did not understand. We can talk about ##\mathbb{Q}\subseteq \mathbb{R}##, ##\mathbb{Q}\subseteq \mathbb{Q}_p##, the p-adic evaluation, but not mixing all these.
This thread is closed now.
Likes WWGD and topsquark
FAQ: Infinity Numbers (Expanded P-Adic Numbers)
What are expanded p-adic numbers?
Expanded p-adic numbers are a generalization of the traditional p-adic numbers, which are used in number theory and algebraic geometry. They extend the p-adic number system to include "infinity" elements, allowing for a more comprehensive framework for dealing with convergence and limits in p-adic analysis.
How do expanded p-adic numbers differ from traditional p-adic numbers?
While traditional p-adic numbers are constructed using a finite valuation and are limited to a specific set of elements, expanded p-adic numbers incorporate additional elements that represent "infinity." This allows for the representation of limits and provides a richer structure that can handle certain types of convergence that traditional p-adic numbers cannot.
What are some applications of expanded p-adic numbers?
Expanded p-adic numbers have applications in various areas of mathematics, including algebraic geometry, number theory, and mathematical logic. They are particularly useful in studying the behavior of sequences and series in p-adic analysis, as well as in the formulation of p-adic cohomology theories.
Can expanded p-adic numbers be used in computational settings?
Yes, expanded p-adic numbers can be utilized in computational settings, especially in algorithms that require precision arithmetic in p-adic contexts. Their structure allows for the efficient handling of infinite series and limits, making them suitable for applications in cryptography, coding theory, and numerical methods in p-adic analysis.
Are there any challenges associated with working with expanded p-adic numbers?
One of the main challenges in working with expanded p-adic numbers is the complexity of their structure, which can make analysis and computations more intricate than with traditional p-adic numbers. Additionally, developing a comprehensive theoretical framework and finding suitable applications can be difficult, requiring advanced knowledge in both p-adic analysis and algebraic structures.
