Ranku
- 422
- 18
By how many times is the size of the observable universe larger than expected because of inflation?
Whether or not there was a period of inflation does not alter the current size of the observable universe. The inflation hypothesis simply helps to explain a number of observed features of the current universe, like its flatness and spatial uniformity. If inflation happened, it occupied only an extremely brief period of time at the very beginning of the period of expansion, so the current age of the universe is not significantly altered. It is the current age that determines the size of the observable universe.Ranku said:By how many times is the size of the observable universe larger than expected because of inflation?
Ranku said:larger than expected
Grinkle said:Your question implies that you think the size of the OU is evidence to support that our early universe underwent an inflationary period.
I think inflation theories are consistent with the observed geometric flatness and uniformity of the OU. I don't think size of the OU per se comes into it. If you have seen discussion to the contrary, please link them - I'd be interested.
Ranku said:a difference in order of magnitude between the two superluminal scales of homogeneity
Ranku said:the size of the observable universe
Ranku said:The horizon problem is a problem if we believe that there is no reason for the universe to have been always homogenous. If the universe was always homogenous, then homogeneity over superluminal scale would be natural. However, if the universe was originally inhomogenous, to explain superluminal scale homogeneity requires inflation, whereby originally inhomogeous regions in proximity had the opportunity to homogenize, and inflation blew up those regions whereby there is homogeneity over superluminal scale.
Now, regardless of whether the universe was always homogenous or not, whether inflation occurred or not, either way we observe homogeneity over superluminal scale. We can therefore compare between a universe which was always homogenous and in which homogeneity would be observed at superluminal scale of a certain order of magnitude, and a universe which was originally inhomogenous and which inflation enables to be homogenous over superluminal scale of a certain order of magnitude. If there is a difference in order of magnitude between the two superluminal scales of homogeneity, would that not be proof of inflation?
I'm not sure if you are aware of the Flatness problem which is a fine-tuning problem and which was solved by assuming inflation too.Ranku said:Now, regardless of whether the universe was always homogenous or not, whether inflation occurred or not, either way we observe homogeneity over superluminal scale.
The theory of inflation proposes that the Universe underwent a rapid expansion in the first fraction of a second after the Big Bang. This rapid expansion is thought to have caused the Universe to grow from a subatomic size to its current size, making it much larger than it would have been without inflation.
Scientists use various methods to measure the size of the Universe, including the cosmic microwave background radiation, the expansion rate of the Universe, and the distance to distant galaxies. These measurements are then used to estimate the current size of the observable Universe.
Based on current observations and theories, it is believed that the size of the Universe is infinite. However, the observable Universe is limited by the distance light has been able to travel since the beginning of the Universe, so we are only able to see a small portion of the entire Universe.
The size of the Universe is constantly changing due to the expansion of space. The rate of this expansion, known as the Hubble constant, is currently increasing, which means that the Universe is getting larger at an accelerating rate.
The size of the Universe has a significant impact on our understanding of the laws of physics. For example, the large size of the Universe allows us to test and validate theories such as the theory of relativity and quantum mechanics. Additionally, the size of the Universe also affects the formation and evolution of galaxies, stars, and planets, which are all governed by the laws of physics.
