Inflation rate and discount rate?
  • Thread starter Thread starter t0mm02
    Inflation Rate
To incorporate an average yearly inflation rate of 2.10% and a discount rate of 5.75% into a project with a 6-year payback period, one can calculate the net present value (NPV) by adjusting each cash flow using the formula (1.021/1.0575)^t, where t represents the time to the cash flow. The NPV is determined by summing these adjusted cash flows. For a more accurate payback period that accounts for inflation and discounting, it is essential to find the smallest time T where the cumulative cash flows become non-negative. This method is particularly effective if negative cash flows occur primarily at the beginning of the project. If cash flows fluctuate between positive and negative, using the internal rate of return (IRR) is recommended for a better assessment.
t0mm02
49
inflation and discount rate
payback
I have a payback for a project of 6 years without counting the inflation rate and discount rate. If the Payback is 6 years, how do you add an average yearly inflation rate of 2.10% and a discount rate of 5.75%?
What do you want to calculate?
If you want a net present value (NPV) you multiply each cash flow by where is the time to the cash flow. Add up those inflated and discounted cash flows to get a NPV.
One way to calculate a payback period using inflated and discounted cash flows is as the smallest T such that the sum of all inflated and discounted cash flows up to time T is non-negative.
This only gives a meaningful number if the main negative cash flows are at the beginning. If the pattern cycles between positive and negative cash flows, payback period is not a helpful measure. Internal rate of return (IRR) would be better.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is , being the parameter. From my side, the only thing I could...
