Influx vs. radius equation, mistake in the dimensions?
In summary, the conversation discusses the definition of Flux and its units as energy passing through a unit area per unit time. The video does not explicitly cover this definition, but it is commonly described as having units of W/m2 or J/(s*m2). The conversation also notes that the professor may have missed including the time unit in their explanation.
Phys12
351
42
The video:
Astronomy news on Phys.org
I do not know if that definition of Flux is covered in the video you posted, but Flux is defined as energy that passes a unit area per unit time. So Flux has units W/m2 or J/(s*m2)
Likes Phys12
Okay, so I guess that the professor missed out on unit per time. He included only the unit per area.
Related to Influx vs. radius equation, mistake in the dimensions?
1. What is the Influx vs. Radius Equation and what does it represent?
The Influx vs. Radius Equation is a mathematical formula that expresses the relationship between the rate of fluid flow (influx) and the distance from the center of a circular opening or pipe (radius). It is often used in fluid mechanics and hydrology to calculate the rate of flow at a specific point in a system.
2. How do you calculate the Influx vs. Radius Equation?
The Influx vs. Radius Equation is typically represented as Q = A * v, where Q is the influx, A is the cross-sectional area of the opening or pipe, and v is the velocity of the fluid. The equation can be derived from the continuity equation, which states that the rate of fluid flow is constant throughout a system.
3. What are the units of measurement for the Influx vs. Radius Equation?
The units of measurement for the Influx vs. Radius Equation will depend on the specific units used for influx, area, and velocity. However, the most common units are cubic meters per second (m3/s) for influx, square meters (m2) for area, and meters per second (m/s) for velocity.
4. What is the most common mistake made when using the Influx vs. Radius Equation?
The most common mistake made when using the Influx vs. Radius Equation is forgetting to use consistent units of measurement. Since the equation involves multiple variables, it is important to ensure that all units are converted to the same system before plugging them into the equation. Otherwise, the results may be inaccurate or invalid.
5. Are there any other factors that can affect the accuracy of the Influx vs. Radius Equation?
Yes, there are other factors that can affect the accuracy of the Influx vs. Radius Equation. These include changes in the fluid's density, viscosity, and temperature, as well as any turbulence or obstructions in the flow. It is important to take these factors into account and make necessary adjustments to the equation to ensure accurate results.
  • Astronomy and Astrophysics
  • Materials and Chemical Engineering
