Info on handling dangerous elements
In summary, handling dangerous elements requires strict adherence to safety protocols, including proper protective equipment, training, and risk assessment. It's essential to understand the properties and potential hazards of the materials, implement containment measures, and ensure good ventilation. Regular monitoring and emergency response plans are crucial to mitigate accidents and ensure safety in the workplace.
Saaz
TL;DR Summary
Risk assessment on handling Sodium, Lithium, Magnesium, Mercury and noble gases, to assets physical and chemical properties under a conventional hood.
Hello,
I want to do an activity with my students where we study some basic properties of some elements of different groups. I'm concerned about some hazards with some of these elements. I work under a simple fume hood.
My concerns are:
- Pure Sodium/lithium/magnesium: Is it safe to handle at room temperature and standard humidity conditions? Once in stored in mineral oil, how safe is it to keep it in chemical storage? Given that all the groups together might use 0.2 g of Na, would the H2 produced be an hazard?
- Mercury: is it safe to put a couple of drops of mercury in the watch glass at room temperature? I'm mostly concerned about the fumes and the inhalation hazards.
- Noble gases: I saw some small Tesla coil to excite the noble gases (eg powered by a 9V battery); how safe are these tesla coils? Are there some hazards?
I would appreciate any information that you have about it!
Best,
Saaz
Chemistry news on Phys.org
Grouping sodium/lithium with magnesium makes little sense. Do you mean potassium? Alkalis can be stored in mineral oil for a fairly long time.
Don't use mercury in class. Even though elemental mercury isn't as dangerous as many think, kids are incredibly stupid.
Tesla coils, no idea.
Likes BillTre, berkeman and pinball1970
Thanks for the reply Mayhem! I meant magnesium since I want to show an element from groups I and II (so sodium/lithium and magnesium).
Ok.
Magnesium can be stored in ambient conditions. It burns brightly at very high temperatures, but nothing you would be likely to encounter by accident.
Depends on the definition of "safe". If we are talking about subgram amounts it is difficult to harm yourself permanently, but you can definitely burn fingers or something like that.
A lot depends on legaleze and regulations you need to adhere to (and chances you will be chased by parents).
I'm definitely talking about subgram amounts. For Na I was thinking of trying something like 0.025 g in water. However, the stock would be 1 g of Na. Maybe I can divide the sample stock into 5 containers under oil and work with one of them each time.
Is it safe to cut Na under room conditions without having it to react with the humidity of the air?
Reasonably safe. I did it several times in eighties and I am apparently still alive.
Likes Astronuc and Saaz
Your set up looks reasonably safe, but normal PPE should be used to prevent skin contact with the alkali metals. For 0.02g of Na, the amount of H2 produced will be negligible, so no real hazard there. Tesla coils use high frequency rf transformers to generate high voltages and are reasonably safe if working correctly (rf travels on the surface of any conductor) - the risk is more in the inner, low voltage/high current coils should there be any defects.
Likes Tom.G
