Information on large scale structure?
In summary, the conversation revolves around recommendations for useful links and articles on large scale structure formation and understanding the cold dark matter model. The role of initial perturbations and thermodynamic anisotropies in the evolution of the universe is also discussed. Various articles and resources are suggested, including "Physics of the Intergalactic medium" and "Particle Physics of the Early Universe" by Uwe-Jens Wiese, as well as "ASTROPHYSICS AND COSMOLOGY" by Juan Garcıa-Bellido. The subject of dark matter and its interactions with other particles is also mentioned, with the paper "Correlation Function of Dark Matter Haloes" being suggested. Finally, the conversation concludes with the potential impact of
sketos
56
Can anyone recommend some usufull links,pdf,... for information on large scale structure?
I want to fully understand how in the cold dark matter model the the hierarchical formation of matter occurs and the role of the initial perturbations in the evolution of the universe.
Thank you.
Space news on Phys.org
How good is your math, particle physics and thermodynamics? I could post numerous highly technical articles on the subject. However if you don't have a good understanding already then they will be difficult to understand. Dark matter is one contributor to large scale structure formation but thermodynamic anisotropies also play a factor.
Much of this is covered in this article, however its highly technical
http://arxiv.org/abs/0711.3358
good stepping stone articles covering the metrics involved in the previous article would be these two below
The thermodynamics coverage is pretty good in this article, he also covers the Einstein field equations and FLRW metrics.
http://www.wiese.itp.unibe.ch/lectures/universe.pdf :" Particle Physics of the Early universe" by Uwe-Jens Wiese
This will also be handy its almost a cosmology style textbook so it also covers large scale structure formation
http://arxiv.org/pdf/hep-ph/0004188v1.pdf :"ASTROPHYSICS AND COSMOLOGY"- A compilation of cosmology by Juan Garcıa-Bellido
Also inflation also plays a role, some of the details are covered in this thread
https://www.physicsforums.com/showthread.php?t=749600
A quick and loose breakdown, keep in mind I may forget some of the contributors lol
1) Early universe is in thermal equilibrium= even distribution, also extremely high temperatures over a small volume. Too hot for stable particle interactions.
2)inflation occurs and distributes this high energy plasma evenly
3) inflation slows to a stop but has a reheating phase, at the end of inflation. However some regions stop inflating before other regions, this assists anisotropies in the thermal equilibrium plasma. May or may not also contribute to baryogenesis
4) Due to those anisotropies particles in cooler regions will drop out of thermal equilibrium before others. The various particle species drop out of equilibrium at different temperatures
5) As such the cooler regions will allow matter to form prior to the hotter regions, that matter will start to clump due to gravity. Large scale structure formation starts.
edit: forgot to add this is why the CMB is of great use, the temperature variations left an imprint that we further study LSS formation.
Thank you very much! I am currently on the subject of correlation function of dark matter haloes, which were generated in light-cone simulations. Anything in this topic that you have in mind??
Well there is a lot about dark matter we still don't fully understand. One of the key questions is "does dark matter interact with other weakly interactive particles" such as neutrinos. What we don know of dark matter is that it is cold (non relativistic), a slow moving particle, with a low density. The low density and lack of measured interactions indicate its weakly interactive.
This paper covers one such prospect.
http://arxiv.org/pdf/1401.7597v1.pdf
there is however numerous information on the web correlating structure formation via dark matter. Keep in mind, we still do not completely understand dark matter in regards to thermodynamic processes. So there is, How shall we say alternate conjectures.
http://arxiv.org/pdf/0909.2021.pdf, Dark Matter and Galaxy Formation
http://arxiv.org/abs/astro-ph/9707285 Dark Matter and Structure Formation in the Universe (older article but still has good information)
http://arxiv.org/abs/astro-ph/9801234 Structure Formation with Generalized Dark Matter (older as well
http://arxiv.org/abs/astro-ph/9711259 The Structure and Dynamics of Cold Dark Matter Halos
http://arxiv.org/abs/astro-ph/9710329 Inside-out Galaxy Formation
http://arxiv.org/abs/astro-ph/9910246 Galaxy Formation and Large Scale Structure
those should get you started you will notice I stuck to www.arxiv.org. You can browse there for more papers, which will give you non multi-media articles on the subject
edit:eek:ne key point is that if DM and neutrino interactions are shown via observations, then the thermodynamics of LSS will probably need updating, may or may not be an earlier contributor
Likes 1 person
Related to Information on large scale structure?
1. What is large scale structure?
Large scale structure refers to the organization and distribution of matter on a large scale in the universe. This includes the arrangement of galaxies, clusters of galaxies, and superclusters, as well as the voids in between them.
2. How is large scale structure measured?
Large scale structure is measured using various methods, including galaxy surveys, cosmic microwave background radiation, and gravitational lensing. These techniques provide information about the distribution, clustering, and motions of matter on a large scale.
3. Why is studying large scale structure important?
Studying large scale structure can provide insights into the evolution and formation of the universe, as well as the properties of dark matter and dark energy. It also helps us understand the role of gravity in shaping the structure of the universe.
4. What is the current understanding of large scale structure?
The current understanding of large scale structure is based on the theory of inflation and the Lambda Cold Dark Matter (ΛCDM) model. This model suggests that the universe is made up of about 5% normal matter, 25% dark matter, and 70% dark energy, and that the distribution of matter on a large scale is influenced by the gravitational pull of dark matter.
5. How does large scale structure affect the formation of galaxies?
Large scale structure plays a significant role in the formation and evolution of galaxies. The regions with higher concentrations of matter, such as clusters and superclusters, have a stronger gravitational pull, which can cause gas and dust to collapse and form galaxies. The voids, on the other hand, have lower densities and can hinder or delay the formation of galaxies.
