Information transmitted at speeds greater than C
In summary, the conversation discussed the possibility of communicating information faster than light by using a tube made of diamond and a beam of light. However, it was concluded that this is not possible as the speed of sound in any material, including diamond, cannot exceed the speed of light. The conversation also recommended a video and a forum discussion for further understanding on this topic.
alex.enduro73
Hello,
a question for all of you with its experiment.
If I have a material that has a Bulk modulus higher, the diamond type (442 GPa) if I create a tube of diamond along 1 miles (or length less) with appropriate supports to decrease as much as possible the friction.
At the same time I have a source with a beam of light, and on the other end I receiver measures the time that I was late arriving light.
The tube ends in a diamond has a servo for actuating the movement of longitudinal movement that can be recorded from the other end with a sensor.
By activating both instantly (or in sequence it is important to measure the latency), motion tube diamond and activation beam of light, which would be the information that will come first?
If it should be noted the movement of the tube with a latency less than the arrival of the light beam will have discovered a way of communicating information faster than light. thanks
Alexander
A mechanical signal is never faster than light, because on the atomic level it is also based on EM forces. I recommend you this video:
Likes alex.enduro73
Lets say you hit the end of the diamond tube with a hammer. The shock wave will travel down the tube at the speed of sound in diamond which according to this web page is "only" 12,000 meters per second. Quite a bit slower than the speed of light.
http://www.engineeringtoolbox.com/sound-speed-solids-d_713.html
The speed of sound in any material cannot exceed the speed of light for the reasons given in the video at about 4mins in.
There is a FAQ on this topic over in the relativity forum:
https://www.physicsforums.com/threads/can-i-send-a-signal-faster-than-light-by-pushing-a-rigid-rod.536289/
Hello Alexander,
Thank you for sharing your experiment and question. It is an interesting concept to consider the use of a material with a high Bulk modulus, such as diamond, to potentially transmit information faster than the speed of light. However, it is important to note that the speed of light, or the speed of any electromagnetic wave, is considered to be the ultimate speed limit in the universe according to Einstein's theory of relativity.
While your experiment may show a delay in the arrival of the light beam due to the movement of the diamond tube, it is not necessarily evidence of information being transmitted faster than the speed of light. This is because the movement of the tube itself is limited by the speed of sound in the material, which is significantly slower than the speed of light.
In addition, there are other factors to consider such as the time it takes for the servo to activate the movement of the tube and the time it takes for the sensor to detect the movement. These delays could also contribute to the perceived latency in the arrival of the light beam.
Overall, it is important to approach any claims of faster-than-light communication with caution and to consider the physical limitations and principles that govern our universe. Thank you for your interesting experiment and question.
FAQ: Information transmitted at speeds greater than C
What is information transmission at speeds greater than C?
Information transmission at speeds greater than C refers to the transmission of data or information at a speed faster than the speed of light (C). This is currently considered to be impossible according to Einstein's theory of relativity, which states that the speed of light is the maximum speed at which anything can travel.
Is it possible for information to travel faster than the speed of light?
According to our current understanding of physics, it is not possible for information to travel faster than the speed of light. The speed of light is considered to be the ultimate speed limit in the universe, and any attempts to exceed it would result in the violation of fundamental laws of physics.
How does the speed of light affect information transmission?
The speed of light is a fundamental constant in the universe and plays a crucial role in information transmission. It is the fastest speed at which information can travel, and any attempts to exceed it would result in a violation of causality, where an effect could occur before its cause.
Are there any theories that suggest information can travel faster than the speed of light?
There are some theories, such as the Alcubierre drive, that suggest the possibility of faster-than-light travel. However, these are still theoretical and have not been proven to be feasible. In addition, they do not necessarily involve the transmission of information, but rather the bending of space-time to achieve faster travel.
What are the implications of information transmission at speeds greater than C?
If information could be transmitted at speeds greater than C, it would completely change our understanding of the universe and the laws of physics. It would also allow for instantaneous communication over vast distances, making space travel and exploration much easier. However, at this point in time, it is still considered to be impossible.
