Infra Red Emittor and Collector
In summary, the behavior of infra red rays depends on the design of the emitter. They can work the same as lasers or spread out like a flashlight. The intensity profile or bell shaped curve of the beam can provide information on the design. The Fairchild component in question has an IR LED in a recessed hole, indicating some angular spread, but the specific angle is not stated in the datasheet.
Jones1987
77
Do infra red rays spread out or do they work the same as lasers and fire in a single ray?
Example if I have the emittor at different distances from the object it is scanning (e.g a ground surface say 10mm and 30mm distances) do the rays spread and further to cover a wider range, or do they fire down straight no matter the distance?
Thanks.
That depends on the emitter. Infrared light works the same way as visible light. It can be coherent as in a laser or diffuse like a flashlight.
Even lasers spread out. In general, every source does. It is a matter of design.
It surely spreads to some degree, but it may not be relevant. The information you may need would be the intensity profile, or the intensity of the beam as a function of the exit angle. This should be some kind of bell shaped curve I(theta). What you are asking for is the shape of this curve. Only the manufacturer can provide such information (or anyone else who has the device and has bothered to the measurement).
Jones1987 said:
What are the tell tale signs of how the component is designed? How will I know if it is set-up to fire in a line, or create a spread?
This is the component I've been looking at:
http://www.active-robots.com/products/sensors/sensors-fairchild.shtml
That page has a link to http://www.active-robots.com/products/sensors/fairchild/qrb113x.pdf" which has a scale drawing of the part. Looks like the beam is emitted by an IR LED in a recessed hole. So the beam will have some angular spread, but there's nothing in the datasheet telling us how big that angle is.
Related to Infra Red Emittor and Collector
1. What is an infra red emitter and collector?
An infra red emitter and collector is a device that emits and collects infrared radiation, which is a type of electromagnetic radiation with longer wavelengths than visible light. This technology is commonly used in remote controls, motion sensors, and thermal imaging cameras.
2. How does an infra red emitter and collector work?
The emitter consists of a material that converts electrical energy into infrared radiation, while the collector has a material that can absorb and convert infrared radiation into electrical energy. When the emitter is turned on, it emits infrared radiation that is then collected by the collector, allowing for communication or detection of objects.
3. What are the applications of an infra red emitter and collector?
Infra red emitters and collectors have a wide range of applications, including wireless communication, thermal imaging, and object detection. They are also used in security systems, medical devices, and industrial automation.
4. What are the advantages of using an infra red emitter and collector?
One of the main advantages of this technology is that it can transmit and receive information wirelessly without the need for a direct line of sight. Additionally, it is not affected by visible light, making it useful in low-light or dark environments. It also has low power consumption and is relatively inexpensive.
5. Are there any limitations to using an infra red emitter and collector?
One limitation of this technology is its short range compared to other wireless communication methods. It also requires a clear line of sight between the emitter and collector, as any obstruction can disrupt the transmission. Additionally, it can be affected by external sources of infrared radiation, such as sunlight or heat sources.
  • Mechanical Engineering
  • Electrical Engineering
  • Quantum Physics
  • Science Fiction and Fantasy Media
15K
  • Classical Physics
  • Other Physics Topics
