Initial energy of a charged particle
In summary: The question asked what the initial energy of the particle would have to be when it is within 4.7 * 10^-15 m of a gold nucleus. It also states that 4.7 * 10^-15 is the radius of the gold nucleus. Therefore, the distance from the centre of the gold nucleus to the alpha particle is 2(4.7 * 10^-15 m). Am I misunderstanding the question?Yes, but the question asks what the initial energy of the particle would have to be when it is within 4.7 * 10^-15 m of a gold nucleus. It also states that 4.7 * 10^-15 is the radius of the gold nucleus. Therefore, the distance from the centre of the
skweeegor
Ernest Rutherford in his lab at McGill University, Montreal, fired alpha particles of mass 6.64 * 10^-27 kg at gold foil to investigate the nature of the atom. What initial energy must an alpha particle (charge +2e) have to come within 4.7 * 10^-15 m of a gold nucleus (charge +79e) before coming to rest? This distance is approximately the radius of the gold nucleus.
Givens:
m = 6.64 * 10^-27 kg
q_alpha = 2(1.6 * 10^-19 C)
= 3.2 * 10^-19 C
q_gold = 79(1.6 * 10^-19 C)
= 1.264 * 10^-17 C
r_gold = 4.7 * 10^-15 m
d = 4.7 * 10^-15 m
r = r_gold + d
= 9.4 * 10^-15 m
k = 9.0 * 10^9 N*m^2/C^2
E = kq1q2/r
So I know that the total energy of the system when the alpha particle is at rest and r distance from the centre of the gold nucleus is given by the equation E = kq1q2/r.
So, E = [(9.0*10^9)(3.2*10^-19)(1.264*10^-17)] / 9.4 * 10^-15
Which gives me E = 3.87 * 10^-12 J
However, this is exactly half of what the solution should be, and I can't seem to figure out why.
Thanks
Distance from the gold nucleus means the distance from its centre.
ehild
Yes, but the question asks what the initial energy of the particle would have to be when it is within 4.7 * 10^-15 m of a gold nucleus. It also states that 4.7 * 10^-15 is the radius of the gold nucleus. Therefore, the distance from the centre of the gold nucleus to the alpha particle is 2(4.7 * 10^-15 m). Am I misunderstanding the question?
Usually the distance from a sphere-like object means the distance from its centre, especially for something which does has not a smooth surface.
When we speak about the distance of Moon from the Earth or the distance of Earth from the Sun, it is the distance between the centres, and not that between the surfaces. How would you take the atmosphere into account? Where does the Earth or the Sun end?
The gold nucleus contains a lot of protons and neutrons with no definite shape and not in rest. You can not compare the size of the nucleus by comparing it with a metre stick. The radius can be defined by an indirect way, buy scattering experiments fro example.
ehild
for your help!
Hello, thank you for sharing your work and question. Your approach and calculations are correct, so I believe the discrepancy in your answer may be due to rounding errors. I would suggest using the exact values for the charges and not rounding them off, as well as using the full value for the radius of the gold nucleus (4.7 * 10^-15 m) in your calculation. This should give you a more accurate result. Additionally, double check your units to make sure they are consistent throughout the calculation. I hope this helps. Keep up the good work in your studies!
Related to Initial energy of a charged particle
What is the definition of initial energy of a charged particle?
The initial energy of a charged particle refers to the total energy possessed by the particle at the beginning of its motion. This includes both kinetic energy, which is the energy of motion, and potential energy, which is the energy associated with the position of the particle in an electric or magnetic field.
How is the initial energy of a charged particle calculated?
The initial energy of a charged particle can be calculated using the formula E = ½mv2 + qV, where m is the mass of the particle, v is its velocity, q is its charge, and V is the electric or magnetic potential. This formula takes into account both kinetic and potential energy to determine the total initial energy.
What factors affect the initial energy of a charged particle?
The initial energy of a charged particle is primarily affected by its velocity, mass, and the strength of the electric or magnetic field in which it is moving. Other factors such as the charge of the particle and the specific type of potential (electric or magnetic) also play a role in determining the initial energy.
Why is the initial energy of a charged particle important to study?
The initial energy of a charged particle is important to study because it helps us understand the behavior of charged particles in different fields. It can also be used to calculate the trajectory and final energy of a particle, which is crucial in many scientific and technological applications.
Can the initial energy of a charged particle change?
Yes, the initial energy of a charged particle can change if the particle interacts with other charged particles or experiences a change in the electric or magnetic field. It can also change due to external forces such as friction or collisions. However, the total energy of the particle (kinetic + potential) will remain constant unless acted upon by an external force.
