Initial speed of an object launched from Mars
The discussion focuses on calculating the initial speed of an object launched from Mars using gravitational potential energy and kinetic energy equations. The user initially miscalculated the initial velocity due to incorrect unit conversion of the radius from kilometers to meters. After correcting the radius, the calculation yielded a revised initial speed of approximately 153,776.815 m/s. The importance of unit consistency in physics calculations is emphasized. The user expresses gratitude for the assistance in identifying the mistake.
marjine
The radius of Mars (from the center of just above the atmosphere) is 3400 km, and its mass is 6 × 1023 kg. An object is launched straight up from just above the atmosphere of Mars. What initial speed (vi) is needed so that when the object is far from Mars, its final speed (vf) is 500 m/s?
G = 6.7E-11
Conservation of energy principle: U1 + K1 = U2 + K2
U1 = -GMm/r
K1 = (1/2)mvi^2
U2 = as r approaches infinity, U2 approaches zero
K2 = (1/2)mvf^2
(1/2)mvi^2 - GMm/r = (1/2)mvf^2 + 0
vi = √(vf^2 + (2GMm)/r) = √(250,000 + 2(6.7 E-11)(6 E23)/3400) = 153776.815
But that is not the correct answer, can anybody see my mistake/misunderstanding?
The radius (r) is given in km, isn't it?
Likes berkeman and PeroK
omg... converted it to m and fixed it, thank you so much
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
