Initial velocity when given distance and acceleration
In summary, the homework statement is that material ejected to a height of 2.00 x 10^5m has an acceleration of 1.80 m/s^2. If you use the equation provided, you can find the time when the material is at it's max height and the initial velocity.
Anester
Material ejected to a height of 2.00 x 10^5m. Acceleration of gravity is 1.80 m/s^2, find initial velocity
v (zero) = v - at.
Seems as though I am missing something since I don't have time or velocity, yet I have distance. Guidance on steps would be appreciated.
If you use like
(Yf - Yi) = Vfx(t) - 1/2(Ay)t^2
You know that when the material reaches it's max height (given in your problem), the velocity of it is zero right?
Yes, makes sense at zero. Though the question is based on a volcano, so I am thinking initial velocity would be when it leaves the cone of the volcano.
Unfortunatley, I am not familiar (or sure) how to use the formula you provided.
It's this equation:
[tex]\Delta y = V_{fy}t - \frac{1}{2}A_{y}t^{2}[/tex]
Delta y is essentially y final minus y initial. If you let the tip of the volcano be 0 on the y axis, you would have the max height = final velocity times time minus one half acceleration due to gravity (given) times time squared. When the final velocity is zero then, you can solve for time to figure out the time when the material is at it's max.
Then I think you can use the fact that:
[tex]V_{fy} = V_{iy} + A_{y}t [/tex] using 0 for final velocity and the solution from the first equation for time to solve for initial velocity.
Unless I am mistaken anyway. I am just learning this material myself.
That first equation is just a derivation of the more common:
[tex]\Delta y = V_{iy}t + \frac{1}{2}A_{y}t^{2}[/tex]
BTW, great handle.
First, how in the world are you able to enter these equations so clearly?
If I understand, the first equation is now 200,000 = (Zero x t) - 1/2 (1.80 x t^2). Concerned unit of measure for A is not correctly represented in my step of the equation
That's right. (Assuming I am correct to begin with). Solving for t will give you the time when the velocity is 0 (the time at the peak), then use the other equation with final velocity as 0 and time as the solution for t, and you should be able to solve for initial velocity.
You can enter equations like this using LaTeX. Right click my equations and select show source to see how it's done. There is also a little latex helper in the text editor on this forum. Just click the capital sigma (E looking thing) while editing a post in advanced mode.
edit: You have to give the code tags like [.tex] code [./tex] (without the periods) The latex helper thing gives itex tags, which are basically the same thing but they print in line with your text.
Now I have a major appreciation when posters such as yourself take the time to present the equations in a clear format. Much more difficult than I imagined.
VERY rough on my Algebra - the first equation would now be
1.8 x 2t^2 = 200,000
The first equation should be:
So plugging in the given values you get:
[tex]200000 = 0t - \frac{1}{2}1.8t^{2}[/tex]
That's simply a quadratic equation right? You might get two answers for t, but remember there is no time travel.
Quarkcharmer, you have been great. I have been helping my son, this is an online exam.
He just told me that he was able to solve with your help and he got it correct.
Really appreciate you taking the time to help out a couple of beginners, your patience is appreciated.
Likes eddddddd
FAQ: Initial velocity when given distance and acceleration
What is initial velocity?
Initial velocity is the velocity of an object at the beginning of its motion. It is typically represented by the variable u and is measured in meters per second (m/s).
How is initial velocity calculated when given distance and acceleration?
The formula for calculating initial velocity is u = √(v2 - 2as), where v is the final velocity, a is the acceleration, and s is the distance traveled. If any of these values are missing, the equation can be rearranged to solve for initial velocity.
Can initial velocity be negative?
Yes, initial velocity can be negative if the object is moving in the negative direction. This indicates that the object is moving backwards or in the opposite direction of the positive value on the chosen coordinate system.
How does initial velocity affect the motion of an object?
Initial velocity is an important factor in determining an object's motion. It determines the object's speed and direction at the beginning of its motion, and it can also affect the object's acceleration and final velocity.
Can initial velocity change during an object's motion?
Yes, initial velocity can change if there is a change in acceleration or if an external force is applied to the object. Otherwise, the initial velocity remains constant throughout the object's motion.
