Injective Function: Proving Correctness with Singlets ##S## and ##T## in ##X##
  • Thread starter pepos04
  • Tags
    Function
In summary, the document discusses the concept of injective functions, focusing on the correctness of such functions using specific sets, denoted as ##S## and ##T##, within a set ##X##. It outlines the necessary conditions for a function to be injective, emphasizing the importance of unique mappings from elements of ##S## to ##T##. The proof involves demonstrating that if two elements in ##S## map to the same element in ##T##, it leads to a contradiction, thereby confirming the injective nature of the function.
pepos04
41
Hi. Given a function ##f## from ##X## to ##Y##, an exercise asked me to establish whether, given two subsets of ##X## (for example ##T## and ##S##), therefore ##f (T \cap S) = f (T) \cap f (S)##, if and only if ##f## is injective.
I operated by placing ##S## and ##T## to two singlets belonging to ##X## and therefore established that for ##T, S \in X##, therefore ##f (T) = f (S) \implies S = T##, consequentially: $$f (T \cap S ) = f (T \cap T) = f (T) \cap f (T) = f (T) \cap f (S)$$. I would like to know if my procedure is correct and if there are still any shortcomings. Thank you.
pepos04 said:
Homework Statement: Hi. Given a function ##f## from ##X## to ##Y##, an exercise asked me to establish whether, given two subsets of ##X## (for example ##T## and ##S##), therefore ##f (T \cap S) = f (T) \cap f (S)##, if and only if ##f## is injective.
I’m no mathematician but am wondering if you have stated the question completely and correctly.
As I understand it, the argument of a function must be an element of a set. So writing expressions such as ##f (T \cap S)## or ##f (S)## seems wrong and ambiguous.
Also, if ##S## and ##T## are singleton sets, I would have thought this would need to be explicitly stated in the question. It doesn't seem like an assumption you should need to make yourself for the question to make sense.
Relevant Equations: \
This is a statement that [itex]f[/itex] is injective. Is that the direction of the equivalence you are attempting to prove? If so, please state that expressly.
If [itex]T[/itex] is a singleton subset of [itex]X[/itex], then it is incorrect to say that [itex]T \in X[/itex]. If [itex]T = \{t\}[/itex] then [itex]t \in X[/itex] and [itex]T \subset X[/itex]. But you don't have to name singleton sets; instead name the elements inside them (ideally as [itex]x[/itex] and [itex]y[/itex]) since the definition of injectivity of [itex]f[/itex] is stated in terms of individual elements of [itex]X[/itex].
If you are assuming that [itex]f[/itex] is injective, then your aim is to prove a statement about arbitrary subsets of [itex]X[/itex]. Better to start with the assumption that they are indeed arbitrary, rather than singletons.
I would start by showing that if [itex]f[/itex] is injective, then for all [itex]x \in X[/itex] and all [itex]T \subset X[/itex] we have [itex]f(x) \in f(T)[/itex] if and only if [itex]x \in T[/itex].
Likes PeroK and FactChecker
By definition, if [itex]f: X \to Y[/itex] then for [itex]T \subset X[/itex], [tex]f(T) \equiv \{ f(x) : x \in T \} \subset Y[/tex] and for [itex]W \subset Y[/itex], [tex]
f^{-1}(W) \equiv \{x \in X: f(x) \in W \} \subset X[/tex] where the latter is well-defined even if [itex]f[/itex] is not itself invertible.
Likes PeroK and Steve4Physics
Thanks. I didn't know that.
The text asks me: given a function ##f## from ##X## in ##Y##, prove that for every pair ##S, T## of subsets of ##X##, equality ##f(S \cap T) = f(S) \cap f(T)## holds if and only if the function ##f## is injective.
I exploited the fact that only with the injectivity of the function could that equality be achieved
This needs a lot of work. A valid proof of this would have several parts and you should be clear in each part, what you are assuming and prove one part at a time.
When proving any "A if and only if B", there are at least two things to prove:
1) If A then B
2) If B then A.
When proving that two sets, C and D, are equal, there are at least two things to prove:
1) ##x \in C, \implies x \in D##
2) ## x \in D \implies x \in C##
So I would expect a proof with several sections. State clearly what is being assumed in each section of the proof and make it clear what the result is.
Likes PeroK
The key phrase is 'every pair ##S, T## of subsets'. You could do this...
1) Show that if ##f## is injective, then ##f (T \cap S) = f (T) \cap f (S)## for all possible pairs ##S, T##.
2) Show that if ##f## is not injective, then at least one pair ##S, T## can be chosen such that ##f (T \cap S) \ne f (T) \cap f (S)##. The 'trick' is to make a suitable choice for ##S, T##.
Likes PeroK
This might help the OP, without giving too much away in terms of the solution to this particular problem.
For any subsets, ##T, S##, and any function ##f##, we have:
$$f(T \cap S) \subseteq f(T) \cap f(S)$$Proof:
$$y \in f(T \cap S) \ \Rightarrow \ \exists x \in T \cap S: f(x) = y$$Now
$$x \in T \cap S \ \Rightarrow \ x \in T \ \text{and} \ x \in S$$$$\Rightarrow \ y \in f(T) \ \text{and} \ y \in f(S)$$$$\Rightarrow \ y \in f(T) \cap f(S)$$QED
FAQ: Injective Function: Proving Correctness with Singlets ##S## and ##T## in ##X##
What is an injective function?
An injective function, or one-to-one function, is a function in which every element of the codomain is mapped by at most one element of the domain. In other words, if f(x1) = f(x2) implies x1 = x2 for all x1 and x2 in the domain, then the function is injective.
How do you prove a function is injective using singlets S and T in X?
To prove a function is injective using singlets S and T in X, you need to show that if f(S) = f(T), then S must equal T. This involves assuming that f(S) = f(T) and then demonstrating through logical steps or algebraic manipulation that S = T.
What are some common methods for proving injectivity?
Common methods for proving injectivity include:1. Direct proof: Assume f(x1) = f(x2) and show x1 = x2.2. Contrapositive proof: Show that if x1 ≠ x2, then f(x1) ≠ f(x2).3. Using derivatives: For functions defined on intervals, if the derivative is always positive or always negative, the function is injective.
Can you give an example of proving a function is injective?
Sure, consider the function f(x) = 2x + 3. To prove it is injective, assume f(x1) = f(x2). Then 2x1 + 3 = 2x2 + 3. Subtracting 3 from both sides, we get 2x1 = 2x2. Dividing by 2, we get x1 = x2. Thus, the function is injective.
What is the significance of injective functions in mathematics?
Injective functions are significant because they preserve distinctness; no two different elements in the domain map to the same element in the codomain. This property is crucial in various fields such as algebra, calculus, and computer science, particularly in areas involving mappings, transformations, and data integrity.
