Injectivity equivalent to having a left inverse
This is because there would be elements in the range that do not have a corresponding element in the domain. Therefore, the properties of injectivity and surjectivity are related to the existence of inverses, as they determine whether the inverse of a function can fully "undo" the function's effect or not. In summary, the properties of injectivity and surjectivity are related to the existence of inverses in a function. A left inverse can "undo" the effect of a function, while a right inverse may not be defined on all elements if the function is surjective.
Mr Davis 97
1,462
44
I know that one can easily prove the result that a function is injective if and only if that function has a left inverse. But is there intuitive reason for this? Same goes for the fact that having a right inverse is equivalent to being surjective. Why are the properties of injectivity and sujectivity related to inverses?
Mathematics news on Phys.org
When a left inverse is applied to a function, as in ##f^{-1}\circ f(x)##, it 'undoes' the effect of the function because, under the right-to-left rule for function composition, ##f^{-1}## is applied after ##f##. If the function was not injective ##f^{-1}## could not map back to the original ##x## because there would be more than one possibility.
When a right inverse is applied, as in ##f\circ f^{-1}(y)##, the right inverse ##f^{-1}## will not be defined on all elements of its domain - which is the range of ##f## - if ##f## is surjective.
Likes fresh_42
FAQ: Injectivity equivalent to having a left inverse
What is injectivity?
Injectivity is a property of a mathematical function where each input has a unique output. In other words, no two different inputs can have the same output.
What is a left inverse?
A left inverse is a function that reverses the inputs and outputs of another function. In other words, it "undoes" the original function.
How is injectivity related to having a left inverse?
Injectivity is equivalent to having a left inverse because if a function is injective, then it has a unique output for each input. This means that the function can be "undone" by a left inverse, resulting in the original input.
Why is injectivity important in mathematics?
Injectivity is important because it ensures that a function has a well-defined inverse, which is essential in many areas of mathematics such as linear algebra and calculus. It also allows for the simplification and manipulation of equations.
Can a function have a left inverse but not be injective?
No, a function cannot have a left inverse if it is not injective. This is because a left inverse must "undo" the original function, and if the original function is not injective, then multiple inputs could have the same output, making it impossible for the left inverse to reverse the function.
