Inner product of a vector with an operator
In summary: However, if you restrict the wavefunction to a subset of all functions that are zero on the boundary, then the operator is still Hermitian on that subset.
EquationOfMotion
So say our inner product is defined as ##\int_a^b f^*(x)g(x) dx##, which is pretty standard. For some operator ##\hat A##, do we then have ## \langle \hat A ψ | \hat A ψ \rangle = \langle ψ | \hat A ^* \hat A | ψ \rangle = \int_a^b ψ^*(x) \hat A ^* \hat A ψ(x) dx##? This seems counter-intuitive. Say our operator is ##\frac{d}{dx}## and ##ψ(x)=x##. Then, evidently ## \langle \hat A ψ | \hat A ψ \rangle = b-a## and ## \langle ψ | \hat A ^* \hat A | ψ \rangle = 0##, which is obviously incorrect. What am I missing?
You must consider the correct brackets. ##\langle A\psi , A\psi \rangle = \int_a^b (A(\psi))^*(x)(A(\psi))(x)dx## and ##\frac{d}{dx}(\psi)=\psi## if ##\psi = \operatorname{id}##.
Careful! The differential operator is not Hermitian on the set of all functions. Try with a valid wave-function on an interval.
Doesn't moving around the operators in an inner product work regardless of whether or not it's Hermitian?
Yes, but you have to work out what the Hermitian conjugate of your operator is. That's assuming it has one.
Likes bhobba and EquationOfMotion
Ooh, so it does always work as long as you know what the Hermitian conjugate is, but you of course *need* the correct conjugate. Thanks!
The proof of The Hermicity of ##d/dx## involves integration by parts and taking the term evaluated on the boundary to be zero, where the range is either ##R## or a finite interval. The function ##x## does not vanish on the boundary, so the operator is only Hermitian on a suitable subset of all functions.
Technically, therefore, all valid wavefunctions must be zero on the boundary.
Likes bhobba
Related to Inner product of a vector with an operator
1. What is an inner product of a vector with an operator?
An inner product of a vector with an operator is a mathematical operation that takes two vectors as inputs and produces a scalar value as an output. It is a way to measure the similarity or "closeness" between two vectors.
2. How is the inner product of a vector with an operator calculated?
The inner product of a vector with an operator is calculated by multiplying the components of the first vector with the corresponding components of the second vector and then summing up the results. The resulting scalar value is the inner product.
3. What is the significance of the inner product of a vector with an operator?
The inner product of a vector with an operator has many applications in mathematics, physics, and engineering. It is used to define the length of a vector, the angle between two vectors, and the projection of one vector onto another. It also plays a crucial role in defining and understanding linear transformations.
4. How is the inner product of a vector with an operator related to the dot product?
The inner product of a vector with an operator is essentially the same as the dot product. The only difference is that the inner product can be defined for more general vector spaces, while the dot product is only defined for Euclidean spaces. In other words, the dot product is a special case of the inner product.
5. Can the inner product of a vector with an operator be negative?
Yes, the inner product of a vector with an operator can be negative. This can happen when the angle between the two vectors is greater than 90 degrees. In this case, the resulting scalar value will be negative, indicating that the two vectors are pointing in opposite directions.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
