Insane Jet Maneuvers, where do they get the mass flow?
In summary, the conversation discusses the effects of inlet distortion on fan performance and how it relates to fighter jets and their ability to maintain mass flow without stalling the compressors. The speakers also mention various methods and tools used to measure and manage inlet distortion in compressor testing. A thesis is also shared as a resource for further information on the topic.
wesmac
So I am doing a presentation on effects of inlet distortion on fan performance, I am trying to gauge it more towards the inlet aspect, diverting boundary layers, etc. So I am wondering, how do fighter jets pull such quick turns, and still maintain enough mass flow not to stall the compressors? I mean, i know they have variable inlets and bleed, and the like, even IGV`s, but something just doesn't make sense, you have to have uniform flow into the compressor or lots of bad things happen...right?!
Happy Thanksgiving!
We spend a lot of time designing compressors to survive with non ideal inlet conditions. The performance definitely takes a hit in those instances but luckily they are short lived events.
When we do compressor testing in the cells, we purposely distort the inlet flow to examine stall margin with non-ideal inlets. Before the airframe sees an engine, that engine has seen most of its flight envelop on the ground.
I see. Thanks for the info! Hadnt looked at it in that aspect
To add to what Fred said, we can use things like distortion screens which can be tuned to the amount of expected distortion.
Also, for quantifying the amount, I'm not sure what method you're using, but we have typically used the KD2 method in the past. It's a method that I know at least the Air Force uses as well.
A quick google gave me this thesis which looks like it has a lot of good background information if you want to dive deeper.
http://dspace.mit.edu/bitstream/handle/1721.1/42186/22926364.pdf?sequence=1
FAQ: Insane Jet Maneuvers, where do they get the mass flow?
What is an insane jet maneuver?
An insane jet maneuver is a type of flight maneuver performed by high-performance fighter jets that involves extreme acceleration, deceleration, and changes in direction. These maneuvers are often used in air combat situations to evade enemy fire or gain a tactical advantage.
How do insane jet maneuvers affect the mass flow of the aircraft?
During an insane jet maneuver, the aircraft experiences significant changes in speed and direction, resulting in changes in the mass flow of air over the aircraft's surfaces. This can impact the stability and control of the aircraft, requiring skilled pilots and advanced flight control systems to maintain control.
Where does the mass flow come from during an insane jet maneuver?
The mass flow during an insane jet maneuver comes from the engines of the aircraft. The engines intake large amounts of air, compress it, mix it with fuel, and ignite it to create thrust. This thrust is what allows the aircraft to perform these extreme maneuvers.
Are there any risks associated with performing insane jet maneuvers?
Yes, there are risks associated with performing insane jet maneuvers. These maneuvers put a high amount of stress on the aircraft and can cause structural damage if not performed correctly. They also require highly skilled and trained pilots to execute safely.
Can insane jet maneuvers be used in commercial aircraft?
No, insane jet maneuvers are not used in commercial aircraft. These maneuvers are only performed by highly specialized military fighter jets. Commercial aircraft are designed for safe and efficient travel and do not have the same capabilities or need for extreme maneuvers.
