Krushnaraj Pandya
- 73
A circular ring (2m, R) with a small insect of mass m on its periphery, is placed upon smooth horizontal surface (axis of rotation passing through center and perpendicular to the ground i.e disk is lying horizontally)
. The insect starts moving with velocity v w.r.t ground along the periphery. The angular velocity of rotation of ring is (note*-I just have a problem with one step of the solution)
net torque=dL/dt
I got the correct answer as v/2r by conserving angular momentum about O (center of disk). What I don't understand is how the net torque about it is zero- surely, the insect must have had to give an impulse to rotate the disc at w from rest, even if for a short time
