Inserting a subscript in the text in the following diagrams app.
In summary, the conversation was about the difficulty of adding a subscript to a subscript in a certain app. The person asking the question was informed that it is not possible to do so in the app, but they could use other methods such as using "_" or using LaTeX with the app's mathematical typesetting feature. Thanks was given for the helpful advice.
MathematicalPhysicist
373
I want to inset the following text ##f_{2,G_2}##, but it seems I cannot include a subscript to ##G## in the following app:
https://app.diagrams.net
am I missing something? can it be done?
Thanks!
Computer science news on Phys.org
Works for me using the x2 button highlighted below
I mean how to write the second 2 in ##G_2##? where I want the following to be typed: ##f_{2,G_2}##.
MathematicalPhysicist said:
can it be done?
Subscript to a subscript? It seems that is not possible.
Likes MathematicalPhysicist and pbuk
OK, then I'll use the old "_".
It looks like an emoticon... :oldbiggrin:
Or maybe use something else, like tikz in LaTeX (which is, BTW, a bit complex).
Oh I see!
Select Extras -> Mathematical typesetting and then you can use ## \LaTeX ## e.g. \(f_{2,G_2}\)
https://www.diagrams.net/doc/faq/math-typesetting
Likes MathematicalPhysicist and Wrichik Basu
pbuk said:
Oh I see!
Thanks, you are a genius! should have played around with the app myself, I guess I would have found it eventually... nonetheless thanks!
FAQ: Inserting a subscript in the text in the following diagrams app.
How do I insert a subscript in the text using the diagrams app?
To insert a subscript in the text using the diagrams app, follow these steps:
1. Select the text you want to add a subscript to.
2. Click on the "Text" tab in the top menu.
3. In the "Text" tab, click on the "Subscript" button.
4. The selected text will now have a subscript added to it.
Can I insert a subscript in the middle of a word using the diagrams app?
Yes, you can insert a subscript in the middle of a word using the diagrams app. Simply follow the steps mentioned in the answer to the previous question.
Is it possible to change the size or style of the subscript in the diagrams app?
No, the diagrams app does not have the feature to change the size or style of the subscript. It will appear as a smaller and slightly lowered version of the normal text.
Can I add a subscript to multiple words at once in the diagrams app?
Yes, you can add a subscript to multiple words at once in the diagrams app. Simply select all the words you want to add a subscript to and follow the steps mentioned in the answer to the first question.
How can I remove a subscript from the text in the diagrams app?
To remove a subscript from the text in the diagrams app, follow these steps:
1. Select the text with the subscript.
3. In the "Text" tab, click on the "Subscript" button again to toggle it off.
4. The subscript will now be removed from the selected text.
