Instability of an atomic clock
In summary, the conversation discusses the different ways of measuring the stability of an oscillator or clock. While journalists often use a simpler representation of the clock losing 1 second in XX million/billion years, professionals use the more accurate method of measuring the Allan deviation in a plot. This plot shows the fractional stability over time and cannot be summarized into a single number. However, one can calculate the stability for a specific measurement time and determine the percentage of time lost. This percentage is not fixed and can vary due to technical or physical limitations.
Niles
1,866
Hi
When I read "popular" papers on atomic clocks, many journalists write that the clock loses 1 second in XX million/billion years. But when I look at some professional papers, people talk about a fractional instability of e.g. 10-14t-1/2, the authors never use the former way of characterizing the clocks. How does one go from one "representation" to the other?
You can't. At least not properly.
The correct way to measure the stability of an oscillator is to measure the Allan deviation; this will be in the form of a plot with the fractional stabilty on the y-axis and the integration time on the x-axis. Hence, there is no single number that can be used to characherize an oscillator/clock.
What you CAN do is of course to just take the stability for the integration time used to steer the actual clocks, and then calculate what this means in term of say change per million years.
Thanks. The last thing you suggest I tried to do, and I just set t=1 as an example. So I get the fractional instability 10-14 during 1s measurement time. So this means that the clock loses 10-16% of a second during 1 second, right?Niles.
10-14 = 10-12% (as 10-2 = 1%). While accurary usually increases with measurement time, there are some technical or physical limits too - and those determine the minimal deviation.
Note that this deviation is not fixed - otherwise you could simply correct the error (and it would not be an uncertainty).
Related to Instability of an atomic clock
What causes the instability of an atomic clock?
The instability of an atomic clock can be caused by a variety of factors, such as temperature fluctuations, external electromagnetic interference, and aging of the clock's components.
How does temperature affect the stability of an atomic clock?
Temperature fluctuations can cause changes in the frequency of the atoms used in atomic clocks, leading to instability. This is because temperature affects the energy levels of the atoms, which in turn affects their ability to maintain a consistent frequency.
What is external electromagnetic interference and how does it impact atomic clock stability?
External electromagnetic interference refers to any external sources that emit electromagnetic waves, such as electronic devices or power lines. These waves can interfere with the frequency of the atoms in an atomic clock, causing instability and inaccuracies in timekeeping.
Can the instability of an atomic clock be corrected?
Yes, the instability of an atomic clock can be corrected through various methods, such as temperature control, shielding from external electromagnetic interference, and regular maintenance and calibration of the clock's components.
How important is stability in an atomic clock?
Stability is crucial in an atomic clock as it directly affects the accuracy of the clock. A stable clock will have a consistent frequency and therefore provide more precise timekeeping, while an unstable clock will have fluctuations in its frequency and result in less accurate time measurements.
