Python Install pkg from Github to Python 'venv' under VSCode or Pycharm
  • Thread starter Thread starter Swamp Thing
    install
To install the Python package kiwiclient.py from the GitHub repository directly into a virtual environment (venv) using an IDE like PyCharm or VSCode, the most straightforward method is through the terminal. First, activate the venv in the terminal and then execute the command: pip install git+https://github.com/jks-prv/kiwiclient. For users on Python 3, it's recommended to use pip3. If Python 2.7 is not installed, pip will default to pip3, ensuring compatibility with Python 3. For those less familiar with Python, PyCharm or VSCode may require additional setup to run terminal commands effectively within the IDE.
Swamp Thing
Insights Author
I would like to install the Python package kiwiclient.py from this github repo :
into a venv using an IDE like PyCharm or VSCode.
Is there a way to do this directly without cloning the repo locally?
If not, what are the steps to clone and install into a project's venv?
I am not particularly proficient in either Python, PyCharm or git so I would appreciate a detailed guide with few prerequisite skills.
Platform: Raspberry Pi OS
Technology news on Phys.org
This would be straightforward if you do it from the terminal. Activate the venv in the terminal first. Then run:
Code:
Source.
Likes Swamp Thing and Greg Bernhardt
Greg Bernhardt said:
Use pip3 if on Python3
Doesn't it automatically use pip3 if Python 2.7 is not installed?
Likes Greg Bernhardt
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
