Installing older version gcc@9.3.0 using brew?
  • Thread starter CAF123
In summary: What is your PATH variable set to? I'm using MacPorts, and I'm pretty sure on installation that it added /opt/local/bin and /opt/local/sbin, which are where it places executables, to PATH. I'd guess Homebrew does something similar.Mine is set to:/usr/local/Cellar/gcc@9/9.3.0_1/bin:/usr/local/Cellar/gcc/9.3.0_1/sbin:/usr/local/Cellar/gcc/9.3.0_1/usr/bin:/usr/local/Cellar/gcc/9.3
CAF123
88
I'd like to install gcc version 9.3.0 on my Mac Os Big Sur. I was wondering if I can do this still using brew?
I already have the most up to date version of brew but I would like to possibly downgrade or have in addition gcc v9.3.0.
I followed the three commands below
brew tap-new $USER/local-gcc`
brew extract --version=9.3.0 gcc $USER/local-gcc`
brew install gcc@9.3.0`
but when I do
brew info gcc
it still says I have v10.2.0. Is there a way to switch between different versions? As far as I can tell brew switch is now broken.
If there is another way to get a working gcc v 9.3.0 that you can recommend I am happy to try it too. Thanks in advance.
Computer science news on Phys.org
Probably you posted this same question at Stack Overflow as well, right?
First check if brew list --versions gcc returns the old version. If it does, then probably you can use brew switch gcc 9.3.0 to go to the old version and use it.
If it doesn't return the old version, we have to think of something else.
N.B.: I do not have a PC running macOS, so all my help will be based on the internet.
Likes CAF123
Hi @Wrichik Basu
Yes
brew list --versions gcc returns gcc 10.2.0_4 however brew list --versions gcc@9 returns gcc@9 9.3.0_1. Also, as far as I know, now brew switch is obsolete.
I see, thanks.
I ran across a question about using different versions of Python, and someone replied telling the user to use brew link. I've never used Homebrew (or at least it's been so long I don't remember trying it out), so it might be a completely useless suggestion.
Likes CAF123
Hi @vela
Thanks, I had tried brew link gcc@9 and it says Already linked: /usr/local/Cellar/gcc@9/9.3.0_1. I have never symlinked before so not sure if I am using brew link in the correct way here. Do you know?
Also, a little bit more broadly, why doesn't adding the explicit path of my gcc@9 to my .zshrc work? E.g. adding
export PATH=$PATH:/usr/local/Cellar/gcc@9/9.3.0_1 to the top of the shell?
It sounds like it, but I'm pretty ignorant about Homebrew.
Because you're adding the directory to the end of the path, that's the last place the system will look for gcc. You could try tacking it on the front instead.
The command which gcc will tell you which gcc the system will use by default.
Likes CAF123
Thanks.
I didn't quite understand what you meant by 'tacking it on the front instead'. Could you explain a bit more there?
which gcc returns /usr/bin/gcc and which gcc@9 returns gcc@9 not found . Seems strange given e.g. the output of brew ls --versions gcc@9 in #3 but maybe I'm being naive.
If PATH is set to, say, "directory 1:directory 2", the system first searches directory 1 for the program you're trying to run, and if it can't find it there, it then looks in directory 2. Because you added the gcc9 directory to the end, that's the last place the system will look for gcc. To make it the first place it looks, put it at the beginning of PATH. That said, you probably shouldn't add that directory, which likely contains a lot of other stuff, to PATH.
If you were to look in /opt/local/bin (or whatever the corresponding directory for Homebrew is), you should find an executable or symbolic link called gcc. Try checking the version of that to see which one is installed by Homebrew.
I'm pretty sure the older version of gcc creates an executable called gcc, not gcc@9.
Likes CAF123
Thanks, in /usr/local/opt I find gcc, gcc@10, gcc@9 while in /usr/local/bin I find gcc-10 and gcc-9. I think the former are symbolic links and the latter are the executable files (following https://mkyong.com/mac/where-does-homebrew-install-packages-on-mac/). I'm just not really clear on how to tell the system to use compiler gcc-9 rather than I guess gcc or gcc-10 that it is using now.
Please show show us the output of
  • ls -l /usr/local/bin/gcc*
  • ls -l /usr/local/opt/gcc*
  • echo $PATH
Thanks, see below for the various outputs,
lrwxr-xr-x 1 <me> admin 33 Mar 9 14:58 /usr/local/bin/gcc-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-10
lrwxr-xr-x 1 <me> admin 33 Mar 2 09:52 /usr/local/bin/gcc-9 -> ../Cellar/gcc@9/9.3.0_1/bin/gcc-9
lrwxr-xr-x 1 <me> admin 36 Mar 9 14:58 /usr/local/bin/gcc-ar-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-ar-10
lrwxr-xr-x 1 <me> admin 36 Mar 2 09:52 /usr/local/bin/gcc-ar-9 -> ../Cellar/gcc@9/9.3.0_1/bin/gcc-ar-9
lrwxr-xr-x 1 <me> admin 36 Mar 9 14:58 /usr/local/bin/gcc-nm-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-nm-10
lrwxr-xr-x 1 <me> admin 36 Mar 2 09:52 /usr/local/bin/gcc-nm-9 -> ../Cellar/gcc@9/9.3.0_1/bin/gcc-nm-9
lrwxr-xr-x 1 <me> admin 40 Mar 9 14:58 /usr/local/bin/gcc-ranlib-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-ranlib-10
lrwxr-xr-x 1 <me> admin 40 Mar 2 09:52 /usr/local/bin/gcc-ranlib-9 -> ../Cellar/gcc@9/9.3.0_1/bin/gcc-ranlib-9
lrwxr-xr-x 1 <me> admin 22 Mar 9 14:58 /usr/local/opt/gcc -> ../Cellar/gcc/10.2.0_4
lrwxr-xr-x 1 <me> admin 22 Mar 9 14:58 /usr/local/opt/gcc@10 -> ../Cellar/gcc/10.2.0_4
lrwxr-xr-x 1 <me> admin 23 Mar 2 09:52 /usr/local/opt/gcc@9 -> ../Cellar/gcc@9/9.3.0_1
lrwxr-xr-x 1 <me> admin 27 Mar 2 10:37 /usr/local/opt/gcc@9.3.0 -> ../Cellar/gcc@9.3.0/9.3.0_1
vela said:
echo $PATH
/usr/local/opt/gnu-tar/libexec/gnubin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin:/usr/local/bin/gcc-9:/usr/local/Cellar/gcc@9/:/usr/local/Cellar:/usr/local/bin/gfortran:/usr/local/bin
Use gcc-9 to run the older version and gcc-10 to run the newer version. Plain old gcc will run the compiler that comes with Xcode.
You should probably remove /usr/local/bin/gcc-9, /usr/local/Cellar/gcc@9/, and /usr/local/Cellar from PATH. You also have /usr/local/bin in there twice, so remove one of them.
Likes CAF123
Thanks very much, yes so gfortran-9 myfile.f, gfortran-10 myfile.f or gfortran myfile.f all respond correctly to a simple Hello World test program while gcc-9 myfile.f, gcc-10 myfile.f or gcc myfile.f do not. Should that be the case?
The software in question that requires v9 of gcc is installed via an installation script by ./ installation_script (along with other dependencies which seem to not require this downgraded version of gcc). As I am only writing in the terminal ./ installation_script, would you know how to modify this command so as to let the script know to use gcc-9?
I don't know.
It depends. The script might be written so you can somehow specify which gcc to use. If not, it's probably easiest to modify the script so it uses gcc-9, e.g., alias gcc to /usr/local/bin/gcc-9.
Likes CAF123
Thanks, I had tried adding alias gcc=‘gcc-9’ but it didn't immediately work. Secondly, I had tried a symlink from gcc to gcc-9 via
ln -sf /usr/local/bin/gcc-9 /usr/local/bin/gcc
Now, gcc --version gives
gcc (Homebrew GCC 9.3.0_1) 9.3.0 Copyright (C) 2019 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
which is what I want but
brew ls gcc --version is still gcc 10.2.0_4 .
The command you asked for before, ls -l /usr/local/bin/gcc* is now
lrwxr-xr-x 1 <me> admin 20 Mar 13 18:46 /usr/local/bin/gcc -> /usr/local/bin/gcc-9
lrwxr-xr-x 1 <me> admin 20 Mar 13 20:54 /usr/local/bin/gcc-10 -> /usr/local/bin/gcc-9
lrwxr-xr-x 1 <me> admin 36 Mar 13 18:10 /usr/local/bin/gcc-ar-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-ar-10
lrwxr-xr-x 1 <me> admin 36 Mar 13 18:10 /usr/local/bin/gcc-nm-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-nm-10
lrwxr-xr-x 1 <me> admin 40 Mar 13 18:10 /usr/local/bin/gcc-ranlib-10 -> ../Cellar/gcc/10.2.0_4/bin/gcc-ranlib-10
while ls -l /usr/local/opt/gcc* is
lrwxr-xr-x 1 <me> admin 22 Mar 13 18:10 /usr/local/opt/gcc -> ../Cellar/gcc/10.2.0_4
lrwxr-xr-x 1 <me> admin 22 Mar 13 18:10 /usr/local/opt/gcc@10 -> ../Cellar/gcc/10.2.0_4
So, I can think of two things to try next: make all references of gcc-10 to gcc-9 in the output of ls -l /usr/local/bin/gcc* or/and make /usr/local/opt/gcc -> ../Cellar/gcc/10.2.0_4 instead read /usr/local/opt/gcc -> ../Cellar/gcc@9/9.3.0_1 or something.
I don't have much experience messing with such things and I'm always worried that I do something that messes up the whole system and nothing can compile.
FAQ: Installing older version gcc@9.3.0 using brew?
How do I install an older version of gcc@9.3.0 using brew?
To install an older version of gcc@9.3.0 using brew, you can use the following command: brew install gcc@9.3.0. This will install the specified version of gcc on your system.
How do I check the version of gcc that is currently installed on my system?
To check the version of gcc that is currently installed on your system, you can use the command gcc -v in your terminal. This will display the version of gcc that is currently installed.
Can I have multiple versions of gcc installed on my system?
Yes, you can have multiple versions of gcc installed on your system. Each version will be installed in a separate directory and can be accessed by specifying the version number in the command.
How do I switch between different versions of gcc?
To switch between different versions of gcc, you can use the command brew switch gcc@9.3.0. This will switch to the specified version of gcc on your system.
How do I remove an older version of gcc installed using brew?
To remove an older version of gcc installed using brew, you can use the command brew uninstall gcc@9.3.0. This will uninstall the specified version of gcc from your system.
