Installing Snap Ring on a Shaft with Larger OD
  • Thread starter Thread starter harpoon
    Ring Shaft
Installing a snap ring rated for 5 mm shafts onto a 6 mm shaft is highly challenging and not advisable. The snap ring is designed to fit a 4.8 mm groove, and attempting to stretch it over the larger diameter will likely cause it to buckle and twist. Creating a helical turn to fit the snap ring over the shaft complicates the installation further, making it difficult to flatten once seated. It is suggested to consider using a snap ring specifically designed for 6 mm shafts instead. Exploring alternative solutions is recommended for better results.
harpoon
Hello! Long story short, I am interested in installing a snap ring rated for 5 mm diameter shafts over a 6 mm diameter shaft into the appropriate groove. For several reasons, I cannot use other types of retaining rings (i.e. side mount E-style retaining rings, etc). This is the snap ring:
https://www.mcmaster.com/90154A101/
Unfortunately, I am not able to quickly get my hands on a rotary shaft with the proper grooves and retaining rings to test this out experimentally. Assuming I have the proper installation tools and that the groove is properly sized to fit the snap ring, is this possible, or will it be too difficult to open the snap ring 1 mm farther than the rated OD of the snap ring? In general, how far can I open a snap ring over its rated shaft OD until it yields or gets damaged?
Thank you in advance! Let me know if I should clarify anything.
I have installed and removed a lot of snap rings over the years. Without knowing any details I can only say go by the manufacturer specs. I've worked with snap rings that are seemingly too small for the shaft yet are oem sourced. I've also seen the time that in my opinion they are too loose and also oem sourced.
harpoon said:
... is this possible, or will it be too difficult to open the snap ring 1 mm farther than the rated OD of the snap ring?
It is designed to pass over a 5 mm diameter shaft, to seat in a 4.8 mm diameter groove. To pass it over a 6 mm shaft, into a 4.8 mm diameter groove will be very difficult. It will buckle and twist. You will need to make it into a long helical turn to pass it over the 6 mm shaft. It will then be difficult to flatten it again as it is seated in the deep groove. Cutting the deeper groove in the 6 mm shaft will be difficult, and the ring will only just show above the lip.
Why not use a 6 mm ring on the 6 mm shaft?
That split in the snap ring will have to open up to at least 4.08mm to get a 6mm dia. In reality, probably a bit more considering that much deformation will not be uniform. Good luck with that!
I recommend finding a different solution.
Cheers,
Tom
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
