Instantaneous Acceleration Given Equation for Velocity
amandela
Thread moved from the technical forums to the schoolwork forums
This is from an old exam.
The velocity of a particle moving along a straight line is v = 4 + 0.5 t. What is the instantaneous acceleration at t=2?
The solution is supposedly 2 because a = dv/dt = t. But I thought dv/dt here would be 0.5. What am I missing?
Thanks.
Welcome to PF.
Where are you seeing a solution of 2? dv/dt for that equation is indeed 0.5 if you've written the equation correctly.
Likes amandela
amandela said:
v = 4 + 0.5 t
Should this be ??
Likes Steve4Physics, PeroK, berkeman and 1 other person
Welcome to PF.
Thank you. I think I lost an exponent!
Orodruin said:
Should this be ??
Yes, I went back and checked again b/c the displacement was wrong, too, and I missed the exponent. Thank you!
Likes WWGD and berkeman
The velocity of a particle moving along a straight line is v = 4 + 0.5 t^2
What's your opinion about the dimensionality of that equation? The lefthand side is a velocity and the righthand side is a number plus a time squared. Is that valid?
In my opinion the equation is only valid for a set of units where the appropriate conversion constants all turn out to be equal to one.
There should be units on the and units on the . The computed result would then have units for the . Also units for the given value of . The first derivative of that would then have units for the acceleration.
Likes PeroK
Lower level textbooks often introduce dimensionless quantities such as ”velocity m/s or simply do not use units at all.
Likes amandela
