Instantaneous center of rotation
In summary: One thing at a time:The centre of rotation has to be on a point directly below the centre, otherwise the velocity has a y-component. Hint: the speed is proportional to the distance from the centre. So, how far do you have to go to get to a speed of...?
edgarpokemon
93
<Mentor's note: ^Moved from a technical forum and therefore no template.>
at the instant shown during deceleration, the velocity of the tire is 40 ft/s to the right and the velocity of point A is 5ft/s to the right. locate the instantenous center of rotation.
Can the instantaneous center of rotation C be located below A? I also used Vo= Va + (w×ro/a) where w is the radial velocity and ro/a is the distance of o with respect to a. I get a value of 35 rad/s for w clockwise, but if it is clockwise, then shouldn't A be pointing to the left? help!
http://tinypic.com/r/2n7f7g2/9
What's your definition of "instantaneous centre of rotation"?
as its name suggests?
Since you asked the following question:
It clearly isn't so obvious.
so the center of rotation (C) will be located between points O and A? my books says that if two velocities are known and are parallel, it says to draw a perpendicular line from the tail of one of the vectors to the tail of the other velocity, and then draw a line from the tip of one vector to the tip of the other vector until it intersects with the perpendicular line, and that happens below point A.
That's not a definition. Anyway, I guess you mean:
https://en.wikipedia.org/wiki/Instant_centre_of_rotation#Pure_translation
In which case it is not necessarily part of the body. You need to imagine the whole plane as a rigid body and find a point on the plane which is instantaneously at rest.
One hint, although perhaps it's too late, is that you don't need to calculate the angular velocity. Think instead about the motion relative to the centre of the wheel. The wheel is moving at ##40ft/s##, a point on the rim directly below the centre is moving at ##5ft/s##, so that's ##-35ft/s## relative to the centre. So, which point is moving at ##-40ft/s## relative to the centre?
would that be point A? It asks me to locate the instantaneous center of rotation and then calculate everything from there, which includes to find the velocities of point B and D, which i found by using the calculated angular velocity of 35. I think that the wheel is always moving, so the instantaneous center of rotation is not on the wheel but outside the wheel, but i am not sure where! i found the problem in google and they the velocity of A pointing to the left, even though the problem states it is pointing to the right.
Hint: the speed is proportional to the distance from the centre. So, how far do you have to go to get to a speed of ##40ft/s##?
would that be 1.143ft below point O?
Who knows? You might know the radius of the wheel, but I certainly don't!
Do you mean ##\frac{40}{35} R##, where ##R## is the radius of the wheel?
oh right! sorry the tire has a diameter of 24 inches, so the radius is 1 ft.
Related to Instantaneous center of rotation
What is the concept of instantaneous center of rotation?
The instantaneous center of rotation is a point in a body or system that has zero velocity at a particular instant in time. It is the point around which all parts of the body are rotating at the same rate and direction.
How is the instantaneous center of rotation calculated?
The instantaneous center of rotation can be calculated using the velocity vectors of two points on the rotating body. The point of intersection of these two vectors is the instantaneous center of rotation.
What is the significance of the instantaneous center of rotation?
The instantaneous center of rotation is a crucial concept in understanding the motion of a body or system. It helps in analyzing the velocity and acceleration of different parts of the body and can be used to determine the direction and magnitude of forces acting on the body.
Can the instantaneous center of rotation change?
Yes, the instantaneous center of rotation can change depending on the motion of the body or system. It can also change if the forces acting on the body change in direction or magnitude.
What are some real-world applications of the instantaneous center of rotation?
The concept of instantaneous center of rotation is used in various fields, including engineering, biomechanics, and robotics. It is used to design efficient and stable mechanical systems, analyze human movement, and develop advanced robotics and prosthetics.
  • Mechanics
