Instantaneous velocity of a object in projectile motion
Velocity is measured in m/s, not m/s2.In summary, the problem states that a stone is thrown horizontally with an initial velocity of 8.0 m/s, with negligible air resistance. The average acceleration due to gravity is 9.8 N/Kg downwards. The task is to find the horizontal and vertical components of displacement and instantaneous velocity at different times. Instantaneous velocity refers to the velocity at a specific moment in time, and can be found using Pythagoras' theorem.
NightRunnerz
stone is thrown horizontally with a initial speed of 8.0 m/s (Vxi)
Air resistance is negligible. average acceleration due to gravity = 9.8 N/Kg (down) [ay]
dx= Vxi/ time
Vfy= vyi + ay x time
Instantaneou velocity equation? :S
okay so it tells me to find horizontal and vertical components of displacement and instantaneous velocity at time=0.0s/1.0s/2.0s and 3.0s isn't Vyi given (initial y velocity SINCE it's 0?) and (vxi is also give - 8.0 m/s)
BUt how do i find INSTANTANEOUS velocity?
Welcome to PF!
Hi NightRunnerz! Welcome to PF! :smile:
NightRunnerz said:
… how do i find INSTANTANEOUS velocity?
Instantaneous velocity just means the velocity at that particular moment (ie, the word "instantaneous" is unnecessary :rolleyes:)
(and if you need the speed, use Pythagoras! :wink:)
OKAY so by velocity you mean V as in speed right?
dotdotdot m/s2?
...m/s2?
Hi NightRunnerz! :smile:
(just got up :zzz: …)
NightRunnerz said:
okay so it tells me to find horizontal and vertical components of displacement and instantaneous velocity at time …
No, speed and velocity are different.
Speed is the magnitude of velocity.
Velocity has components, speed doesn't.
The question tells you to find the horizontal and vertical components of instantaneous velocity … that's vx and vy.
dotdotdot m/s2?
...m/s2?
m/s2 is acceleration :confused:
I would approach this problem by first understanding the concept of instantaneous velocity. Instantaneous velocity refers to the velocity of an object at a specific moment in time, and it is calculated by taking the limit of the average velocity as the time interval approaches zero. In other words, it is the velocity at a single point in time.
In this case, the object is a stone thrown horizontally with an initial speed of 8.0 m/s and negligible air resistance. The average acceleration due to gravity is given as 9.8 N/Kg (down). To find the instantaneous velocity at different points in time, we can use the equation Vfy = vyi + ay x time, where Vfy is the final velocity, vyi is the initial velocity, ay is the acceleration due to gravity, and time is the elapsed time.
At time t=0.0s, the stone has just been thrown and is at its initial position. Therefore, its initial velocity in the y-direction (Vyi) is 0 m/s, as there is no initial vertical velocity. Plugging this into the equation, we get Vfy = 0 + (9.8 m/s^2)(0.0 s) = 0 m/s. This means that at t=0.0s, the instantaneous velocity of the stone is 0 m/s in the y-direction.
At time t=1.0s, the stone has been in motion for 1 second. Using the same equation, we get Vfy = 0 + (9.8 m/s^2)(1.0 s) = 9.8 m/s. This means that at t=1.0s, the instantaneous velocity of the stone in the y-direction is 9.8 m/s.
Similarly, at t=2.0s and t=3.0s, we can calculate the instantaneous velocity in the y-direction as 19.6 m/s and 29.4 m/s, respectively.
To find the instantaneous velocity in the x-direction, we can use the equation dx = Vxi x time, where dx is the displacement in the x-direction and Vxi is the initial velocity in the x-direction. In this case, the initial velocity in the x-direction is given as 8.0 m/s. Therefore, at t=0.0s, the instantaneous velocity in the x-direction is also 8.0 m/s
FAQ: Instantaneous velocity of a object in projectile motion
1. What is instantaneous velocity in projectile motion?
Instantaneous velocity is the velocity of an object at a specific moment in time. In projectile motion, this refers to the speed and direction of an object at any given point during its flight.
2. How is instantaneous velocity different from average velocity in projectile motion?
Instantaneous velocity is the velocity at a single point in time, while average velocity is the total displacement divided by the total time taken. In projectile motion, the average velocity is the same as the initial velocity, while the instantaneous velocity changes continuously.
3. How is instantaneous velocity calculated in projectile motion?
Instantaneous velocity can be calculated by taking the derivative of the position function with respect to time. This gives the slope of the tangent line at a specific point on the object's trajectory, which represents the instantaneous velocity at that point.
4. Does the instantaneous velocity of a projectile change during its flight?
Yes, the instantaneous velocity of a projectile changes continuously during its flight. This is due to the influence of external forces such as air resistance and gravity, which affect the object's speed and direction at any given moment.
5. Why is understanding instantaneous velocity important in projectile motion?
Instantaneous velocity is important in projectile motion because it helps us understand the motion of an object in more detail. By knowing the object's velocity at different points during its flight, we can make more accurate predictions about its trajectory and make adjustments to improve its performance.
