fog37
- 1,569
- 108
- TL;DR Summary
- Instrument accuracy and comparison measurements
Hello,
All measurement instruments have a finite accuracy. For example, a thermometer may provide a temperature measurement that is +-2F from the "actual" and true temp value. For example, if the reported measurement is 70F, the actual temperature may be between 72F and 68F.
That said, let's assume we have 2 different materials and measure their temperatures ##T_1## and ##T_2##. Both ##T_1## and ##T_2## are affected by the finite accuracy of +-2F but their difference ##|T_1 - T_2|## is not. Is that correct? Even if ##T_1## and ##T_2## are not the actual temperatures, their difference is constant (assuming the same environment conditions). If we repeated, under the same conditions, both measurements 1 hr later, ##T_1## and ##T_2## may assume different values but their difference would be the same...
However, for the same and single material, the finite accuracy imply that multiple measurements would produce different temperature values even under the same conditions...
