Instruments to measure change of state
In summary, the dew point hygrometer works by locally reducing the temperature until the dew point is reached, and recording the temperature at which dew forms. The instrument in the images appears to be a cold trap, with water vapor traveling through the white tube to a meniscus lens and water escaping through the yellow tube into a beaker with boiling water.
Viola
Answer to Q1 : That apparatus has a completely enclosed glass space containing a low-boiling liquid like ether. This space consists of two bulbs connected by a tube. Both bulbs contain some amount of liquid ether, above which is ether vapor at its equilibrium pressure. Now the bulb or the right side is covered in a cloth which is then soaked with more ether. As this ther evaporates from the cloth, it cools down the bulb (and the liquid in the bulb) on the right. As a result of this cooling the vapor pressure above this bulb decreases (some of the vapor condenses into this bulb). This reduced vapor pressure causes the ether in the other (left) bulb to evaporate. This evaporation causes a cooling of the left bulb. At a certain point, the left bulb gets cold enough that a dew starts to form on its outside (from condensation of water vapor in the air). The temperature of the ether in the left bulb at the instant the the dew starts to form is the dew-point.
In short, all you are doing is locally reducing the temperature - slowly and carefully - till it passes the dew-point, and recording it when the dew appears.
Q2 : Can you tell us what runs through the two tubes - the yellow tube feeding into the beaker, and the white tube ? Also, where does the white tube go ?
The white tube goes to a beaker with boiling water, so watervapor travels through the white tube to the meniscus lens (??).
Water escapes through the yellow tube into the beaker.
Thanks for the speedy reply :biggrin:
I'm fairly clueless about what that instrument is. My best guess (not a very good one, I'll admit) would be that it's some kind of cold trap.
FAQ: Instruments to measure change of state
1. What is an instrument to measure change of state?
An instrument to measure change of state is a device or tool used to record and analyze changes in the physical properties of a substance, such as temperature, pressure, or volume, as it undergoes a change from one state to another (e.g. solid to liquid or liquid to gas).
2. What are some examples of instruments used to measure change of state?
Examples of instruments used to measure change of state include thermometers, barometers, manometers, and hydrometers.
3. How do these instruments work?
These instruments work by detecting and measuring changes in physical properties, such as expansion or contraction, in response to changes in the state of a substance.
4. What are the benefits of using instruments to measure change of state?
Using instruments to measure change of state allows for accurate and precise measurements, which are crucial in many scientific and industrial applications. It also allows for the monitoring and control of various processes, such as chemical reactions and phase transitions.
5. Are there any limitations to using instruments to measure change of state?
While instruments to measure change of state are highly useful, they do have some limitations. For example, they may not be able to measure changes in state that occur too quickly or at extreme temperatures. Additionally, the accuracy of measurements may be affected by external factors, such as environmental conditions or the quality of the instrument itself.
