##\int (\sin x + 2\cos x)^3\,dx##
In summary: Then changing the integration variable to ##u = x + \alpha## would simplify the task even more.These terms can be easily integrated using a substitution. There's no need to use the Pythagorean identity here.
Helly123
581
$$\int (sinx + 2cos x)^3dx$$
$$\int (sinx + 2cos x)((sinx + 2cos x)^2dx)$$
$$\int (sinx + 2cos x)(1 + 3cos^2x+2sin2x)dx$$
How to do this in simpler way?
Not sure that it helps, but you could rewrite the original integrand as ##A\sin^3(x+\alpha)##.
First do a binomial expansion of the integrand. That will have only four terms.
The powers of the sine and cosine in each term will either be 3 and 0, or 2 and 1 (unordered pairs). Where they are 2 and 1, use the identity that sine squared plus cos squared equals 1 to turn the squared trig function into the other sort of trig function. Then you will have six terms, each of which is a power of only sine or only cosine.
Then use de Moivre's formula to convert the higher powers into multiple-angle sines or cosines with power 1.
Integration will then be straightforward.
That seems to be more or less the method embarked upon.
Related to ##\int (\sin x + 2\cos x)^3\,dx##
1. What is the purpose of the integral ∫ (sin x + 2cos x)^3 dx?
The purpose of this integral is to find the antiderivative of the given function. This will allow us to find the area under the curve of the function in a specific interval.
2. How do you solve the integral ∫ (sin x + 2cos x)^3 dx?
To solve this integral, we can use the power rule for integration and then apply the chain rule to simplify the expression. This will result in a final antiderivative that represents the area under the curve of the given function.
3. Can this integral be solved using substitution?
Yes, this integral can be solved using substitution. By substituting u = sin x + 2cos x, we can simplify the expression and solve for the antiderivative.
4. What is the range of values for x in which this integral is valid?
This integral is valid for all real values of x. However, if you are trying to find a definite integral, then the range of values for x will depend on the limits of integration.
5. Can this integral be used to find the volume of a solid of revolution?
No, this integral cannot be used to find the volume of a solid of revolution. This integral represents the area under the curve of a function, which is different from the volume of a solid of revolution which requires a different type of integral.
