Inteference Fringes of Double Slit Experiment in Water
In summary, when a double-slit experiment is immersed in water with an index of refraction of 1.33, the interference fringes will be more closely spaced due to the decrease in wavelength in water. This can be calculated using the equation λwater = λair / 1.33 and substituting the value of λ in water instead of air in the equation y = (mλL) / d.
mitchy16
23
Suppose a double-slit experiment is immersed in water (with an index of refraction of 1.33). When in the water, what happens to the interference fringes?
λ = λ0 / n
y = (λmL) / d
d = distance between slits
L = distance to viewing screen
n = index of refraction
So the wavelength in the water would be:
1.33λwater = λair
And then:
ywater = ( (m) (1.33λwater) (L) / d )
The answer is supposedly they will be more closely spaced, but I am not sure why that is correct because wouldn't the distance be 1.33 times that of the original distance?
According to this equation the wavelength in water is less than the wavelength in air, no?
Likes mitchy16
What you're saying here is the same as ywater = ( (m) (λair) (L) / d ).
If you want the value of y in water, you need to use the value of λ in water, instead.
Likes mitchy16
Yes! Thank you, I realize my mistakes now! I retried and it worked out, I appreciate the help!
Related to Inteference Fringes of Double Slit Experiment in Water
1. What is the double slit experiment in water?
The double slit experiment in water is a scientific experiment used to observe the interference patterns produced when light passes through two closely spaced slits in a thin film of water. It is a variation of the classic double slit experiment, which was first performed in 1801 by Thomas Young to demonstrate the wave nature of light.
2. How is the double slit experiment in water conducted?
The double slit experiment in water is conducted by placing a thin film of water between two slits, which are illuminated by a coherent light source such as a laser. The light passing through the slits creates interference patterns on a screen placed behind the water film, which can be observed and measured.
3. What causes the interference fringes in the double slit experiment in water?
The interference fringes in the double slit experiment in water are caused by the superposition of light waves from the two slits. When the waves meet, they either reinforce or cancel each other out, resulting in alternating bright and dark fringes on the screen.
4. How does the interference pattern change when the distance between the slits is varied in the double slit experiment in water?
The interference pattern in the double slit experiment in water changes when the distance between the slits is varied. If the distance between the slits is increased, the fringes become wider and more widely spaced. If the distance is decreased, the fringes become narrower and more closely spaced.
5. What is the significance of the interference fringes in the double slit experiment in water?
The interference fringes in the double slit experiment in water provide evidence for the wave nature of light. This experiment has also been used to study the properties of water, such as its refractive index and surface tension. It has practical applications in fields such as optics and fluid dynamics.
