Inteference of light waves distance of double&single slit
In summary, double slit interference occurs when a single light wave passes through two narrow, parallel slits, while single slit interference occurs when a single light wave passes through a single narrow slit. The distance between the slits affects the spacing of the interference pattern, with increasing distance resulting in a smaller spacing between bright and dark fringes. The distance between the slits and the screen affects the size and definition of the interference pattern. The wavelength of the light wave affects the spacing of the interference pattern, with increasing wavelength resulting in larger spacing between fringes. The intensity of light affects the brightness of the interference pattern, with higher intensity resulting in a brighter pattern and lower intensity resulting in a dimmer pattern.
desmond iking
284
in my textbook, it states that if the single slit together with the light source more closer to the double slit, the intensity of light form double slit increases . hence, the bright fringes of the inteference pattern would be brighter...i couldn't understand why . Can someone explain on this?
Well, I don't understand either. Perhaps the wording got distorted. Could you please rad what you typed and correct the errors ? Otherwise: What textbook might that be ? Does it also provide a drawing of the situation ?
Related to Inteference of light waves distance of double&single slit
1. What is the difference between double and single slit interference?
Double slit interference occurs when a single light wave passes through two narrow, parallel slits, resulting in an interference pattern. Single slit interference occurs when a single light wave passes through a single narrow slit, resulting in diffraction.
2. How does the distance between the slits affect interference patterns?
The distance between the slits affects the spacing of the interference pattern. As the distance between the slits increases, the spacing between the bright and dark fringes decreases.
3. How does the distance between the slits and the screen affect the interference pattern?
The distance between the slits and the screen affects the size of the interference pattern. As the distance increases, the interference pattern becomes larger and less defined.
4. What is the relationship between wavelength and interference patterns?
The wavelength of the light wave affects the spacing of the interference pattern. As the wavelength increases, the spacing between the bright and dark fringes also increases.
5. How does the intensity of light affect interference patterns?
The intensity of light affects the brightness of the interference pattern. Higher intensity light will result in a brighter interference pattern, while lower intensity light will result in a dimmer interference pattern.
