Integer programming model (alternating constraints)
In summary, the problem is to maximize ##x_1 + x_2## subject to ##2x_1 + 3x_2 \le 12## or {##3x_1 + 4x_2 \le 24## and ##-x_1 + x_2 \ge 1##} ##x_1, x_2 \ge 0##. To formulate it as a mixed integer programming problem, we can use large positive constants ##M_1, M_2, M_3## to create redundant constraints. The "loosest" constraint is ##3x_1 + 4x
fishturtle1
394
82
Formulate as a mixed integer programming problem but do not solve. Maximize ##x_1 + x_2## subject to ##2x_1 + 3x_2 \le 12## or {##3x_1 + 4x_2 \le 24## and ##-x_1 + x_2 \ge 1##} ##x_1, x_2 \ge 0##
if the first constraint is met, we have upper bounds ##x_1 = 6, x_2 = 4##,
so ##2x_1 + 3x_2 - 12 \le 2(6) + 3(4) -12 = 12##
if the set of constraints is met, from the first constraint of the set we have upper bounds ##x_1 = 8, x_2 = 6## and from the second constraint of the set we have upper bounds ##(-x_1 \ge 1) \rightarrow (x_1 \le -1) \rightarrow x_1 = 0?, x_2## is not bounded above.
Therefore, for the whole set, we have upper bounds ##x_1 = 0, x_2 = 6##
Therefore, ##3x_1 + 4x_2 - 24 \le 3(0) + 4(6) - 24 = 0##
and ##-x_1 + x_2 - 1 \ge -(0) +(0) - 1 = -1##
So the model is Maximize ##x_1 + x_2##
subject to
##2x_1 + 3x_2 - 12 \le 12(1 - y_1)##
##3x_1 + 4x_2 - 24 \le 0(1 - y_2)##
##-x_1 + x_2 -1 \ge -1(1 - y_2)##
##y \space \epsilon##{0,1} and ##x_i \ge 0## for all i.
the answer key has ##-x_1 + x_2 -1 \ge -7(1 - y_2)## instead of -1 in my third constraint... where did i go wrong?
subject to
You can use ##2x_1+3x_2-12 \leq M_1 (1-y)##, ##3x_1 + 4x_2 -24 \leq M_2 \,y## and ##-x_1+x_2-1 \geq -M_3\, y##, where ##M_1, M_2, M_3>0## are chosen large enough that constraints ##2x_2 + 3 x_2 - 12 \leq M_1##, ##3x_1 + 4x_2 - 24 \leq M_2## and ##-x_1 + x_2 -1 \geq -M_3## are all redundant. It does not really matter a lot what values of the ##M_i## you choose, just as long as they are not much too large: if ##M = 20## will work, do not choose ##M = 2,00,000##.
Among the three constraints, the second one ##3x_1 + 4x_2 \leq 24## is the "loosest", giving ##x_1 \leq 8## and ##x_2 \leq 6##. Therefore, ##2x_1 + 3x_2 \leq 2(8) + 3(6) = 30,## so we can pick ##M_1 = 30-12 = 18##. We have ##3x_1 + 4 x_2 \leq 3(8) + 4(6) = 48##, so we can pick ##M_2 = 48-24 = 24.## Finally, ##-x_1 + x_2 \geq -8 + 0 = -8;## thus ##-x_1 + x_2 - 1 \geq -9## is redundant, so we can pick ##M_3 = 9##.
With a bit more work we might be able to come up with smaller ##M_i##, but I doubt that it is worth worrying about. (It might be worth worrying about if we had ##M_1 = 1800## for example---in a problem where ##M_1 = 18## will do---because that would lead to feasible ##(x_1,x_2,y)## region in the LP relaxation that is long and narrow, thus magnifying the effects of computational roundoff errors and making it harder to distinguish between branches and bounds in a search tree for the integer problem.)
Apparently, your book was able to use ##M_3 = 7## instead of ##M_3 = 9##, but as I said, that is not very important in practice.
Likes fishturtle1 and FactChecker
Ray Vickson said:
You can use 2x1+3x2−12≤M1(1−y)2x1+3x2−12≤M1(1−y)2x_1+3x_2-12 \leq M_1 (1-y), 3x1+4x2−24≤M2y3x1+4x2−24≤M2y3x_1 + 4x_2 -24 \leq M_2 \,y and −x1+x2−1≥−M3y−x1+x2−1≥−M3y-x_1+x_2-1 \geq -M_3\, y, where M1,M2,M3>0M1,M2,M3>0M_1, M_2, M_3>0 are chosen large enough that constraints 2x2+3x2−12≤M12x2+3x2−12≤M12x_2 + 3 x_2 - 12 \leq M_1, 3x1+4x2−24≤M23x1+4x2−24≤M23x_1 + 4x_2 - 24 \leq M_2 and −x1+x2−1≥−M3−x1+x2−1≥−M3-x_1 + x_2 -1 \geq -M_3 are all redundant. It does not really matter a lot what values of the MiMiM_i you choose, just as long as they are not much too large: if M=20M=20M = 20 will work, do not choose M=2,00,000M=2,00,000M = 2,00,000.
Among the three constraints, the second one 3x1+4x2≤243x1+4x2≤243x_1 + 4x_2 \leq 24 is the "loosest", giving x1≤8x1≤8x_1 \leq 8 and x2≤6x2≤6x_2 \leq 6. Therefore, 2x1+3x2≤2(8)+3(6)=30,2x1+3x2≤2(8)+3(6)=30,2x_1 + 3x_2 \leq 2(8) + 3(6) = 30, so we can pick M1=30−12=18M1=30−12=18M_1 = 30-12 = 18. We have 3x1+4x2≤3(8)+4(6)=483x1+4x2≤3(8)+4(6)=483x_1 + 4 x_2 \leq 3(8) + 4(6) = 48, so we can pick M2=48−24=24.M2=48−24=24.M_2 = 48-24 = 24. Finally, −x1+x2≥−8+0=−8;−x1+x2≥−8+0=−8;-x_1 + x_2 \geq -8 + 0 = -8; thus −x1+x2−1≥−9−x1+x2−1≥−9-x_1 + x_2 - 1 \geq -9 is redundant, so we can pick M3=9M3=9M_3 = 9.
Thanks for the reply.
Since we chose the "loosest" constraint's upper bounds, ##U_1 \ge x_1, U_2 \ge x_2## in constraint 3, that means they are also upper bounds of the first constraint's variables and the third constraint's variables, since an upper bound is just some number that is greater than or equal to all ##x_i## of some set ##X##. Then what I did was too much, I can just use the greatest upper bound and apply it to all constraints. Do I understand you?
edit: I am confused.. If we let ##M_i## get bigger or smaller doesn't that mean our set of feasible solutions also changes? And isn't that bad?
I think so, but it is not quite that easy if we have mixed signs in the left-hand-sides of the constraints.
If we let ##M_i## get bigger, the feasible region for the mixed IP problem remains exactly the same, but the feasible region of the LP relaxation gets larger. If it gets a bit larger that will not matter very much, but making it much, much larger that it needs to be is definitely not advisable.
Generally, there is a tradeoff when modelling such situations: should we spend a lot of time and effort getting nearly the best ##M_i## possible, or should we just go with "reasonable" ##M_i## and then get on with the problem-solving process? Of course, generally speaking, the problem solving process is shorter and more efficient if we use smaller ##M_i##, but it is hard to know the exact tradeoff. Remember: in industrial-sized problems like yours we may have hundreds of thousands of variables and tens to hundreds of thousands of constraints, so what looks simple enough in a 2-variable, 3-constraint example might be pretty horrible in a realistic scenario.
That makes sense, thank you.
The point of making the M values large is to get it's constraint out of the way when it is not applicable to the "or" option that is being solved. So a big M value is fine. If making it bigger changes the solution, then it was not big enough to start with.
Likes fishturtle1
FAQ: Integer programming model (alternating constraints)
1. What is an Integer Programming Model?
An Integer Programming Model is a mathematical optimization model that involves decision variables that must take on integer values. This type of model is used to solve problems where the decision variables represent discrete quantities, such as the number of items to be produced or the number of employees to be hired.
2. How does Integer Programming differ from Linear Programming?
Integer Programming models are a type of Linear Programming (LP) model, but with the additional constraint that the decision variables must take on integer values. This makes the problem more complex to solve, as it requires a different approach and specialized algorithms.
3. What are the advantages of using Integer Programming?
Integer Programming allows for more realistic and practical solutions to be obtained for decision-making problems. It also helps to reduce the risk of generating infeasible solutions, as well as providing a more accurate representation of the real-world problem being modeled.
4. What are alternating constraints in an Integer Programming model?
Alternating constraints in an Integer Programming model are constraints that alternate between requiring the decision variable to take on integer values and allowing it to take on any real value. These types of constraints are commonly used in models where certain decision variables are more critical and need to be integer values, while others are less critical and can be any real value.
5. How are Integer Programming models solved?
Integer Programming models are typically solved using specialized algorithms, such as the branch and bound method or the cutting plane method. These algorithms iteratively search for the optimal solution by exploring different combinations of integer values for the decision variables, while also using mathematical techniques to reduce the search space and improve efficiency.
