Integer Solutions for $4^a+4a^2+4=b^2$
  • MHB
  • Thread starter juantheron
  • Tags
    Integer
In summary, there are no integer solutions for $a>4$ and there are two solutions for $a=2$, namely, $(a,b)=(2,3)$ and $(2,6)$.
juantheron
247
Find no. of Integer value of $\left(a,b\right)$ which satisfy $4^a+4a^2+4 = b^2$
Mathematics news on Phys.org
take a =2
[tex] 4^2 + 4(2)^2 + 4 = 4(4 + 4 + 1) = 4(9) [/tex]
[tex] b^2 = 36 \Rightarrow b = \pm 3 [/tex]
Amer said:
take a =2
Actually [tex]b = \pm 6[/tex]
-Dan
try a = 4, b = 18
To see that there are no solutions with $a>4$, notice first that $b$ must be even. Next, the equation $4^a+4a^2+4 = b^2$ can be written as $(2^a)^2+4a^2+4 = b^2$. Since $2^a$ is even, and $b$ is also even, the smallest possible value for $b$ would be $2^a+2$. But $(2^a+2)^2 = 4^a + 2^{a+2} + 4.$ Therefore $$b^2 = 4^a+4a^2+4 \geqslant 4^a + 2^{a+2} + 4 ,$$ from which $4a^2 \geqslant 2^{a+2}$ and hence $a^2\geqslant 2^a.$ That only happens when $a\leqslant 4.$
FAQ: Integer Solutions for $4^a+4a^2+4=b^2$
What is the definition of an integer solution?
An integer solution is a pair of whole numbers (positive, negative, or zero) that satisfies a given equation or inequality.
Can $4^a+4a^2+4=b^2$ have multiple integer solutions?
Yes, the equation can have multiple integer solutions. For example, a=1 and b=3 and a=2 and b=6 are both solutions to the equation.
How can we prove that a given pair of numbers is an integer solution to the equation?
We can substitute the values of a and b into the equation and check if the resulting expression is equal to the given equation. If it is, then the pair is an integer solution.
Are there any patterns or rules for finding integer solutions to this equation?
Yes, there are certain patterns and rules that can be used to find integer solutions. For example, if a is even, then b must also be even. Additionally, if a is odd, then b must be odd.
Can this equation have no integer solutions?
Yes, it is possible for this equation to have no integer solutions. For example, if a is a negative odd number, then the expression $4^a$ will always be negative, making it impossible for the equation to be true.
