Integer Solutions for $4x^2 + 9 y^2 = 72z^2$
  • MHB
  • Thread starter kaliprasad
  • Tags
    Integer
In summary: Apart from the trivial solutions with $a=b=c$, there will be nontrivial solutions whenever $c$ has any prime factors of the form $4k+1.$ For example, if $c=5$ then $7^2+1^1 = 2*5^2 = 50.$ When $c = 13$ we have $17^2+7^2 = 2*13^2 = 338$. With so many solutions, I am not sure that there will be a manageable parametrisation for them.
kaliprasad
MHB
1,335
solve in integers x, y, z(parametric form)
Mathematics news on Phys.org
Re: integer solutions
let $2x=a,3y=b,6z=c$
we get :$a^2+b^2=2c^2$
the only possible sotions will be:$a=b=c$
$\therefore 2x=3y=6z=t$
or $x=\dfrac{t}{2},y=\dfrac{t}{3},z=\dfrac{t}{6}$
where $t\in Z$
where $t\in Z$
is
wrong
where $t\in Z$
EDIT:
sorry in a haste, I made a mistake
2x=a,3y=b,6z=c
for $a,b,c,x,y,z \in Z$
$a^2+b^2=2c^2$
we have :$\pm2x=\pm3y=\pm6z=6t(for \,\,a^2=b^2=c^2)$
$x=\pm 3t,y=\pm 2t,z=\pm t$
where $t\in Z$
[sp]As Albert points out, the problem reduces to finding integer solutions of the equation $a^2+b^2 = 2c^2$. Apart from the trivial solutions with $a=b=c$, there will be nontrivial solutions whenever $c$ has any prime factors of the form $4k+1.$ For example, if $c=5$ then $7^2+1^1 = 2*5^2 = 50.$ When $c = 13$ we have $17^2+7^2 = 2*13^2 = 338$. With so many solutions, I am not sure that there will be a manageable parametrisation for them.[/sp]
Albert said:
EDIT:
sorry in a haste, I made a mitake
for $a,b,c\in Z$
$a^2+b^2=2c^2$
we have :$2x=\pm3y=\pm6z=6t(for \,\,a^2=b^2=c^2)$
$x=\pm 2t,y=\pm 3t,z=\pm t$
where $t\in Z$
a = b =c is wrong conclusion as a = 1 , b = 5, c = 7 satisfies
$2x=a,3y=b,6c=z$
note:$x,y,z,a,b,c \,\, all \in Z$
see post #4
it is manageable and I feel that you can do it.
Albert said:
$2x=a,3y=b,6c=z$
see post #4
[sp]I see now that the way I reduced the problem to $a^2 + b^2 =2 c^2$ is different from that. Starting from the original equation $4x^2 + 9y^2 = 72z^2$, you can see that $x$ must be a multiple of $3$ (because $9$ and $72$ are both multiples of $9$, hence so is $4x^2$). In the same way, $y$ must be a multiple of $2$. If we put $x=3a$ and $y = 2b$, then the equation becomes $36a^2 + 36b^2 = 72z^2$, or $a^2 + b^2 = 2z^2$. Any set of integers $(a,b,z)$ satisfying that equation will give a solution $(x,y,z) = (3a,2b,z)$ of the original equation.[/sp]
the solution will be:
$x=\pm3t,y=\pm2t, z=\pm t$
where $t\in Z$
as mentioned above by Opalg
$(x,y,z) = (3a, 2b , z)$ is a solution when
$a^2 + b^2 = 2z^2$
solution of $a^2 + b^2 = 2z^2$
is given by
$ (a,b,z) = (\pm(m^2-n^2-2mn),\,\pm(m^2-n^2+2mn) \,\pm(m^2+n^2))$
as per http://mathhelpboards.com/challenge-questions-puzzles-28/3-consecutive-terms-ap-perfect-square-8701.htmlso one set of solution
$(x,y,z) = (3a, 2b , z) = (\pm3(m^2-n^2-2mn),\,\pm2 (m^2-n^2+2mn), \,\pm(m^2+n^2)))$
2nd set is
$(x,y,z) = (3b, 2a , z) = (\pm3(m^2-n^2+2mn),\,\pm2 (m^2-n^2-2mn), \,\pm(m^2+n^2)))$
as a and b are interchangeable
edit: one can see that interchanging m and n both the 1st and second sets are same.
so solution is
FAQ: Integer Solutions for $4x^2 + 9 y^2 = 72z^2$
What is the equation $4x^2 + 9 y^2 = 72z^2$ used for?
The equation $4x^2 + 9 y^2 = 72z^2$ is used to find integer solutions for a three-variable Diophantine equation. This means that the equation is looking for whole number solutions for the variables x, y, and z.
How do you solve the equation $4x^2 + 9 y^2 = 72z^2$?
The process of solving this equation involves using number theory methods and algebraic manipulations. One approach is to use the Pythagorean triple method, where the equation is transformed into the form $a^2 + b^2 = c^2$ and then using Pythagorean triples to find solutions.
Are there any restrictions on the values of x, y, and z in the equation $4x^2 + 9 y^2 = 72z^2$?
Yes, there are restrictions on the values of x, y, and z in this equation. They must be integers and there also may be additional restrictions depending on the specific problem being solved.
What are some real-world applications of the equation $4x^2 + 9 y^2 = 72z^2$?
This type of equation has many applications in fields such as cryptography, physics, and engineering. It can be used to solve problems involving distance, velocity, and acceleration, as well as in the design of efficient communication systems.
Can the equation $4x^2 + 9 y^2 = 72z^2$ be solved by hand or does it require a computer?
It is possible to solve this equation by hand, but it can be a complex and time-consuming process. Many mathematicians and scientists use computer programs and algorithms to find solutions to these types of equations more efficiently.
