Integer Solutions of $a^{a+b}=b^{12}$ and $b^{b+a}=a^3$
  • MHB
  • Thread starter anemone
  • Tags
    Integer
In summary, the system of equations has four integer solutions: (a,b) = (4,2), (9,-3), (1,1) and (1,-1). The solutions are obtained by substituting $a = b^2$ from equation (1) into equation (2) to get $b^6 = a^3$. This leads to the quadratic equation $a^2 - 13a + 36 = 0$ with roots (a,b) = (4,2) and (9,-3). The solutions (1,1) and (1,-1) are obtained by considering the case where $a$ and $b$ are both equal to 1. Additionally, the
anemone
MHB
POTW Director
3,883
115
Find all integer solutions of the system
$a^{a+b}=b^{12}$
$b^{b+a}=a^3$
Mathematics news on Phys.org
[sp]\(\displaystyle a^{36} = (a^3)^{12} = (b^{a+b})^{12} = (b^{12})^{a+b} = a^{(a+b)^2}\).
Therefore $(a+b)^2 = 36$, $a+b = 6.$ Then the second equation becomes $b^6 = a^3$ and so $a = b^2$. Hence $$a = (6-a)^2 = 36 - 12a + a^2,$$ $$a^2 - 13a + 36 = 0,$$ $$(a-4)(a-9) = 0,$$ giving the solutions $(a,b) = (4,2)$ and $(a,b)= (9,-3).$[/sp]
Bravo, Opalg! And thanks for participating and your elegant piece of solution!:)
another solutions will be a=b=1
and a=1 ,b=-1
so (a,b)=(4,2),(9,-3),(1,1)(1,-1)
or a=1 ,b=-1
We had better not even think about what happens if $a$ and $b$ are both zero. (Evilgrin)
if $ a=b=0 $
for $0^0 \,\,undefined, $
of course we delete a=b=0 as a set of solution
and a=1 ,b=-1
Cool! Thanks, Albert for catching that...and shame on me because I didn't check with the final solution and was kind of in a haste to reply to Opalg...sorry! :( :eek:
$a^{a+b}=b^{12}---(1)$
$b^{b+a}=a^3---(2)$
taking log function for both sides of (1) and (2)we have :
$\dfrac{log\,a}{log\,b}=4\dfrac{log\,b}{log\,a}$
let $x=\dfrac{log\,a}{log\,b}$
$\therefore x=\dfrac {4}{x}$
$x^2=4 ,\, x=\pm 2$
if $x=\dfrac {log\,a}{log\,b}=2,\, \therefore a=b^2----(3)$
$(1) becomes:a^{a+b}=a^6,\,\, a+b=6---(4)$
from (3)(4) we have (a,b)=(4,2) .and (a,b)=(9,-3)
if $x=\dfrac {log\,a}{log\,b}=-2,\, \therefore a=\dfrac {1}{b^2}$
$\therefore a=b=1 ,\,\, or .\, \, a=1,\,and \,\,\, b=-1$
we conclude :$(a,b)=(4,2),(9,-3),(1,1),(1,-1)$
FAQ: Integer Solutions of $a^{a+b}=b^{12}$ and $b^{b+a}=a^3$
What is an integer solution?
An integer solution is a pair of numbers that satisfy the given equation and are both whole numbers (positive, negative, or zero).
How do you find integer solutions to this equation?
One way to find integer solutions is by trial and error. Start with a pair of numbers and substitute them into the equation. If the resulting equation is true, then those numbers are an integer solution. If not, try a different pair of numbers until you find a solution.
Are there any specific patterns or methods for finding integer solutions to this equation?
Yes, there are certain patterns and methods that can be used to find integer solutions to this equation. One method is to use prime factorization. By breaking down the numbers into their prime factors, you can determine the possible combinations of factors that will result in an integer solution.
Can there be more than one set of integer solutions for this equation?
Yes, there can be multiple sets of integer solutions to this equation. For example, the pair (1,1) and the pair (-1,-1) are both solutions to the equation.
Are there any other types of solutions to this equation besides integer solutions?
Yes, there can be decimal or fractional solutions to this equation as well. However, the given equation specifically asks for integer solutions, so any other types of solutions would not be considered valid in this context.
