Integral calculation using areas
In summary, the integral of (1-2x) from -1 to 2 can be evaluated using the properties of definite integrals and interpreting them as areas. The two areas, one above the x-axis and one below, are equal in magnitude but have opposite signs, resulting in a value of zero for the integral. This can be seen by considering the orientation of the areas and using the absolute value of the integrals to calculate the total area.
mech-eng
828
The problem requires interpreting integrals as areas when calculating. ##\int_1^2 (1-2x)dx##
Are of a triangle is base X height.
Evaluate the integral using the properties of definite integral and interpreting integrals as areas.
##\int_{-1}^2 (1-2x)dx##
I need to see there are two areas and these are the same but one is under x-axis the other is above x-axis so the value of the integral is zero. To see this is difficult to me.
Source: Calculus A Complete Course by Robert A. Adams
Thanks.
Thanks.
In the right hand triangle the height is negative because ##y## is negative. That's why the integral for that part gives a negative area. If you want the geometric area use ##y_{\text{upper}}-y_{\text{lower}} = 0 -(1-2x)## in your integrand for the right hand integral.
One area is oriented: first in direction +x then in direction -y (green), and the other area is oriented: first in direction +x then in direction +y (red), which results in a different sign, because the orientation has changed.
To calculate the area, the absolute values of both integrals have to be added (split att x=1/2), and to calculate the integral, the areas will cancel out to zero.
Related to Integral calculation using areas
1. What is integral calculation using areas?
Integral calculation using areas is a mathematical method used to find the area under a curve on a graph. It involves breaking the area into smaller, simpler shapes and adding them up to find the total area.
2. Why is integral calculation important?
Integral calculation is important because it allows us to solve a wide range of problems in mathematics, physics, and engineering. It is also a fundamental tool for understanding and analyzing functions and their behavior.
3. How is integral calculation related to derivatives?
Integral calculation is the inverse process of differentiation. Just as differentiation is used to find the slope of a curve at a specific point, integration is used to find the area under a curve between two points.
4. What are the different methods of integral calculation?
There are several methods for calculating integrals, including the fundamental theorem of calculus, integration by substitution, integration by parts, and numerical methods such as the trapezoidal rule and Simpson's rule.
5. How can I use integral calculation in real life?
Integral calculation has many real-life applications, such as calculating the area under a velocity-time graph to find displacement, finding the volume of irregular shapes, and determining the amount of work done in physics problems. It is also used in economics, biology, and other fields to model and analyze data.
