Also sprach Zarathustra
- 43
Calculate the following integral:
$$ \int_a^b\frac{dx}{\sqrt{(x-a)(b-x)}} $$
Also sprach Zarathustra said:Calculate the following integral:
Markov said:The most important thing in order to make this work: $b>a.$
An integral calculator is a tool that calculates the definite integral of a given function over a specific interval. It is used to find the area under a curve or the net change of a function.
A definite integral is a mathematical concept that represents the area under a curve between two points on the x-axis. It is represented by the symbol ∫ and has a lower and upper limit of integration, denoted by a and b respectively.
The integral calculator uses a numerical method called the Riemann sum to approximate the area under the curve. It divides the interval into smaller subintervals and calculates the area of each subinterval using the function. The sum of these subinterval areas gives an estimation of the total area under the curve.
The square root in the integral calculator represents the length of a side of a square. In the given function, it is used to calculate the distance between two points on the x-axis, a and b, which are the limits of integration.
The definite integral has various applications in fields such as physics, engineering, and economics. It is used to calculate the area under a velocity-time graph to determine the displacement of an object, find the work done by a force, and calculate the total profit or loss in economics. It is also used to solve optimization problems and find the average value of a function over an interval.
