MHB Integral Challenge: Evaluating $\int_0^\infty \frac{x^2+2}{x^6+1} \, dx$
anemone
MHB
POTW Director
Evaluate $\displaystyle\int\limits_0^{\infty} \dfrac{x^2+2}{x^6+1} \, dx$.
Mathematics news on Phys.org
We have $$I= \int_0^\infty \frac{x^2+2}{x^6+1}\,\mathrm{dx}$$
Let $x \mapsto \frac{1}{x}$ then$$I= \int_0^\infty \frac{x^2+2x^4}{x^6+1}\,\mathrm{dx}$$
So that $$2I = 2\int_0^\infty \frac{1+x^2+x^4}{1+x^6}\,\mathrm{dx}$$
i.e. $$I = \int_0^\infty \frac{1+x^2+x^4}{1+x^6}\,\mathrm{dx}$$By partial fractions $$\begin{aligned} \frac{1+x^2+x^4}{1+x^6} &= \frac{1}{3}\cdot \frac{1}{1+x^2}+\frac{2}{3}\cdot \frac{x^2+1}{x^4-x^2+1} \\& = \frac{1}{3}\cdot \frac{1}{1+x^2} +\frac{2}{3}\cdot \frac{1+1/x^2}{x^2+\frac{1}{x^2}+1} \\& = \frac{1}{3}\cdot \frac{1}{1+x^2} +\frac{2}{3}\cdot \frac{1+1/x^2}{(x-1/x)^2+1}\end{aligned} $$
This along with the sub $u = x-\frac{1}{x}$ helps us finish off the integral,
$$\begin{aligned} I & = \frac{1}{3}\cdot \int_0^\infty \frac{1}{1+x^2}\, \mathrm{dx} +\frac{2}{3}\cdot \int_0^\infty\frac{1+1/x^2}{(x-1/x)^2+1}\,\mathrm{dx} \\& = \frac{1}{3}\cdot \frac{\pi}{2}+\frac{2}{3} \cdot \int_{-\infty}^{\infty} \frac{1}{u^2+1}\,\mathrm{du} \\& = \frac{\pi}{6}+\frac{2\pi}{3} \\& = \frac{5 \pi}{6}.\end{aligned} $$Therefore $$\int_0^\infty \frac{x^2+2}{x^6+1}\,\mathrm{dx}= \frac{5\pi}{6}.$$
Consider the function $\displaystyle f(z) = \frac{z^2+2}{z^6+1}$; $f$ has simple poles at $z = \pm i, \pm i^{\frac{1}{3}}, \pm i^{\frac{5}{3}}$, three of which lie in the upper half plane;
those are $z_1 = i, ~ z_2 = i^{\frac{1}{3}}, ~ z_3 = i^{\frac{5}{3}}$. The sum of the residues at these poles is given by
$\displaystyle \begin{aligned} \sum_{1 \le i \le 3} \text{res} f(z_i) & = \frac{1}{6} (-2 i - \sqrt{3})+\frac{1}{6}(-2 i +\sqrt{3})-\frac{i}{6} \\& = -\frac{5i}{6}\end{aligned} $​
Now, let $\Gamma$ be the upper half-plane semi-circle $|z| = a$ with radius $a$ in counterclockwise direction.
Since $z_1, z_2, z_3$ all lie in the upper half plane, by the residue theorem we have
$\displaystyle \begin{aligned} \oint_\Gamma f(z)\,dz & =2i \pi \sum_{1 \le i \le 3} \text{res} f(z_i) \\& = 2i \pi \cdot \frac{-5i}{6} \\& = \frac{5\pi}{3} \end{aligned}$​
But also
$\displaystyle \oint_\Gamma f(z)\,dz=\int_{-a}^{a} f(z) \,\mathrm{dz} +\int_{\text{Arc}} f(z)\,\mathrm{dz}$​
Therefore
$\displaystyle \int_{-a}^{a} f(z) \,\mathrm{dz} +\int_{\text{Arc}} f(z)\,\mathrm{dz} = \frac{5\pi}{3}$​
By taking $a \to \infty$, since
$ \displaystyle \bigg| \int_{\text{Arc}} f(z) \,\mathrm{dz} \bigg| \le \frac{a^2+2}{a^6-1}~ a \pi \longrightarrow 0$​
we have $\displaystyle \int_{\text{Arc}} f(z)\,\mathrm{dz} \to 0$ as $a \to \infty$, therefore
$\displaystyle \int_{-\infty}^{\infty}\frac{z^2+2}{z^6+1}\,\mathrm{dz} = \frac{5\pi}{3} $​
Therefore (since $f$ is an even function),
$\displaystyle \int_{0}^{\infty}\frac{z^2+2}{z^6+1}\,\mathrm{dz} = \frac{5\pi}{6}. $​
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
