Integral closure of rational polynomial ring
In summary: K$, we know that $f$ must have degree at least $1$.Therefore, $f$ must be a monic quadratic polynomial with integer coefficients. But since $f(\alpha) = 0$, this means that $\alpha$ is algebraic over $\mathbb{Q}[X]$, and hence $\alpha \in \mathbb{Q}[X]$.Thus, $K$ is contained in the integral closure of $\mathbb{Q}[X][Y]$, and so $K = \mathbb{Q}[X][Y]$. In summary, the conversation is about the ring $\mathbb{Q}[X]$ of polynomials in $X$ with coefficients in the field of
pantboio
45
Consider the ring $\mathbb{Q}[X]$ of polynomials in $X$ with coefficients in the field of rational numbers. Consider the quotient field $\mathbb{Q}(X)$ and let $K$ be the finite extension of $\mathbb{Q}(X)$ given by $K:=\mathbb{Q}(X)[Y]$, where $Y^2-X=0$.Let $O_{K}$ be the integral closure of $Q[X]$ in $K$. Certainly $O_{K}$ contains both $\mathbb{Q}[X]$ and $Y$, hence
$$ O_{K}\supseteq \mathbb{Q}[X][Y]$$
My guess is that actually "=" holds. How can be proved this?
Thank u all in advance
Mathematics news on Phys.org
You can prove it by showing that $\mathbb{Q}[X][Y]$ is integrally closed.
It suffices to prove that $\mathbb{Q}[X][Y]$ is integrally closed in its quotient field, which is $K$.
Let $\alpha \in K$ be integral over $\mathbb{Q}[X][Y]$. Since $K$ is a finite extension over $\mathbb{Q}(X)$, we can write $\alpha$ as
$$\alpha = b_0 + b_1 Y + \cdots + b_n Y^n$$
where $b_i \in \mathbb{Q}[X]$ for all $i$.
By writing each $b_i$ as a polynomial in $X$, and then multiplying the whole equation by $X^N$ for some sufficiently large $N$, we can assume that all the coefficients of the polynomials are integers.
Now, let $f$ be the minimal polynomial of $\alpha$ over $\mathbb{Q}[X]$. Since all the coefficients of the above expression are integers, it follows that $f$ has integer coefficients.
But since $Y^2 - X = 0$, this implies that $f$ must have degree at most $2$. Moreover, since $\alpha \
FAQ: Integral closure of rational polynomial ring
What is the definition of integral closure of a rational polynomial ring?
The integral closure of a rational polynomial ring is the smallest ring that contains all elements of the ring and its field of fractions, such that all elements in the closure are integral over the ring.
Why is the concept of integral closure important in algebraic geometry?
The concept of integral closure is important in algebraic geometry because it helps us study the behavior of solutions to polynomial equations, and allows us to extend the notion of algebraic numbers to higher dimensions.
How is the integral closure of a rational polynomial ring related to algebraic extensions?
The integral closure of a rational polynomial ring is closely related to algebraic extensions, as it can be seen as a generalization of algebraic extensions. In fact, for a finite extension field, the integral closure is the same as the algebraic closure.
Can you give an example of computing the integral closure of a rational polynomial ring?
Yes, for example, the integral closure of the polynomial ring Z[x] is the ring of algebraic integers, denoted as Z̄[x]. This can be computed by finding all roots of the polynomial in the complex numbers and then taking the smallest ring containing these roots and Z[x].
How does the integral closure of a rational polynomial ring relate to the ring's Noetherian property?
The integral closure of a rational polynomial ring is always a Noetherian ring. This means that it satisfies the ascending chain condition for ideals, making it easier to study and prove properties of the ring.
