MHB Integral Domains and Principal Ideal Domains (PIDs)
  • Thread starter Thread starter Math Amateur
    domains Integral
To prove that an integral domain R is a Principal Ideal Domain (PID), two conditions must be satisfied: any two non-zero elements must have a greatest common divisor (gcd) expressible as a linear combination of those elements, and a sequence of non-zero elements that divides each subsequent element must stabilize at a unit times a particular element. The proof begins by considering an ideal J in R and selecting an element a1 from J. If J is not already generated by a1, a second element b1 is chosen from J that is not in the ideal generated by a1, allowing the gcd a2 to be formed. This process continues, generating a sequence of elements whose ideals must eventually stabilize, leveraging the second condition to show that J is indeed a principal ideal.
Math Amateur
MHB
Dummit and Foote, Section 8.2 (Principal Ideal Domains (PIDs) ) - Exercise 4, page 282.
Let R be an integral domain.
Prove that if the following two conditions hold then R is a Principal Ideal Domain:
(i) any two non-zero elements a and b in R have a greatest common divisor which can be written in the form ra + sb for some r, s \in R and
(ii) if a_1, a_2, a_3, ... are non-zero elements of R such that a_{i+1} | a_i for all i, then there is a positive integer N such that a_n is a unit times a_N for all n \ge N
I am somewhat overwhelmed by this exercise. I would appreciate it if someone could help me get started and indicate a strategy for formulating a proof.
Peter
Start like this. Let $J$ be an ideal in $R$. We want to show that $J$ is a principal ideal. Choose $a_1\in J$. If $J = \langle a_1\rangle$ (the principal ideal generated by $a_1$), then $J$ is a principal ideal, and we are done. If not, choose $b_1\in J - \langle a_1\rangle$, and let $a_2 = \text{gcd}(a_1,b_1)\in J$. If $J = \langle a_2\rangle$, then $J$ is a principal ideal, and we are done. If not, ... .
Do you see how to continue? The idea should be to use (ii) to show that you can build up a sequence so that $J = \langle a_N\rangle$.
Thanks Opalg ... the overall strategy for proving this is now clear but I do need some help on important aspects of the proof.
You write:
"Start like this. Let $J$ be an ideal in $R$. We want to show that $J$ is a principal ideal. Choose $a_1\in J$. If $J = \langle a_1\rangle$ (the principal ideal generated by $a_1$), then $J$ is a principal ideal, and we are done. ... ... "
I understand this since it is simple logic that something is the case or it is not - true and depends on nothing in the exercise conditions/givens.
Then you write:
"If not, choose $b_1\in J - \langle a_1\rangle$, and let $a_2 = \text{gcd}(a_1,b_1)\in J$. If $J = \langle a_2\rangle$, then $J$ is a principal ideal, and we are done. If not, ... . "When you say " choose $$ b_1\in J - \langle a_1\rangle $$ and let $$ a_2 = \text{gcd}(a_1,b_1)\in J $$ " ... ...
and then go on to say "if $$ J = \langle a_2\rangle $$ ... ... " ... ... I am assuming that there is some logical link between setting $$ a_2 = \text{gcd}(a_1,b_1) $$ and then making the statement " if $$ J = \langle a_2\rangle $$ ... ...
Can you clarify? Can you make the link between the gcd and the principal ideal clear?
Peter
You write:
Then you write:
Peter
The underlying idea is that you want to find an element that generates the whole of $J$. If you start with a random element $a_1\in J$, then $\langle a_1\rangle$ will be contained in $J$ but it might not be the whole of $J$. So you want to find an element $a_2\in J$ that generates a larger part of $J$. If you take $a_2 = \text{gcd}(a_1,b_1)$ then firstly $a_2\in J$ (by condition (i), because $a_2$ is a linear combination of $a_1$ and $b_1$), and hence $\langle a_2\rangle\subseteq J$; secondly, $\langle a_2\rangle$ contains $\langle a_1\rangle$ (because $a_1$ is a multiple of $a_2$); and thirdly, $\langle a_2\rangle$ is strictly larger than $\langle a_1\rangle$ (because $b_1$ is a multiple of $a_2$ and therefore $b_1\in\langle a_2\rangle$, whereas $b_1$ was not in $\langle a_1\rangle$).
Continuing in that way, you build up an increasing nest of sub-ideals of $J$, and then you need to use condition (ii) to show that this process cannot continue indefinitely without eventually encompassing the whole of $J$.
Thanks Opalg
Your post was extremely helpfulPeter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
